Go-Devil foam under the floor
http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=4913
Author:  DU870 [ Mon Sep 28, 2009 10:03 am ]
Post subject:  Go-Devil foam under the floor
I have a Go-Devil 16x44 boat and I removed the water logged foam under my floor this weekend and was wondering do I really need to put foam back under the floor or just leave it out. And what kind of foam to put back if I did that won't soak up water? Thanks.
Author:  lsurebel4 [ Mon Sep 28, 2009 10:13 am ]
Post subject:  Re: Go-Devil foam under the floor
I took mine out last week as well. I called Go Devil and they cut new pieces for me. I would put it back. It only weighs maybe 5-10 pounds at most. Alumimum with no flotation = sink
Author:  go-devil kid [ Mon Sep 28, 2009 3:23 pm ]
Go-Devil sent me another flotation pod to set in the back of the boat to be Coast Guard approved. Did they get a hold of you guys?
Author:  godvl [ Mon Sep 28, 2009 6:43 pm ]
they tried to put that box in my boat, but it takes up too much damn space.
Author:  Gigafowl [ Mon Sep 28, 2009 6:44 pm ]
Could you post a picture of that new pod....
To the original poster - your inside floor and your bottom hull
are "reinforced" by the foam which fits snugly between them
and uses the bottom to stiffen the floor and the floor to stiffen
the bottom....
I had a 16x44 which I bought used where the foam had been
removed but not replaced - it caused the bottom to hook in only
a few runs and the floor was soft also... It is worth the effort
to replace it with factory spec replacement foam - about $ 75
I believe with new rivets too....
Author:  godvl [ Mon Sep 28, 2009 6:49 pm ]
giga- from where the floor starts at the back of the boat, it comes out (probably 24" or more) well past the battery, they have to move the battery back behind the box
Author:  Gigafowl [ Mon Sep 28, 2009 6:50 pm ]
So you stand on it ???
Or it is parallel to the existing pods ???
Author:  godvl [ Mon Sep 28, 2009 6:55 pm ]
its not parallel, it would be right behind your feet, it kinda makes like a back deck on your boat, when cocoa put it in my boat just to see what it would look like, it made it real cramped,
Author:  shallow water master [ Mon Sep 28, 2009 6:58 pm ]
Author:  shallow water master [ Mon Sep 28, 2009 6:59 pm ]
Author:  shallow water master [ Mon Sep 28, 2009 7:02 pm ]
Author:  godvl [ Mon Sep 28, 2009 7:17 pm ]
yall ever remove the foam after you had hydroturf in it? does it tear if you pull it up? how much extra could that wet foam weigh?
Author:  shallow water master [ Mon Sep 28, 2009 8:56 pm ]
Author:  DU870 [ Wed Sep 30, 2009 9:47 am ]
Where would be the best place to pick up some closed cell foam? or should I just call go-devil and get new sent to me?
Author:  shallow water master [ Wed Sep 30, 2009 11:43 pm ]
Author:  tbuc [ Fri Oct 02, 2009 12:56 am ]
Author:  DU870 [ Fri Oct 02, 2009 7:39 am ]
I will go that route, Is it just the sheets that is used to wrap houses and do you just cut it and layer it or does it come thick enough?
Author:  shallow water master [ Sat Oct 03, 2009 11:15 am ]
Author:  bigdtex [ Sun Oct 04, 2009 8:07 am ]
When the foam was removed from my floor, (and it was nasty) I just had them put a little heavier aluminum down for the floor. It worked out great.
Author:  tbuc [ Wed Oct 07, 2009 8:15 pm ]
Author:  CypressIslandBoyy [ Fri Oct 09, 2009 11:54 am ]
So what yall are saying is that, there is foam under where you stand? I checked my foam in the side pods and front and it is soaking wet. Im fixin to remove the front foam and cut a whole for extra storage. Im running a 16-60.
Author:  shallow water master [ Sat Oct 10, 2009 11:32 am ]
Author:  DU870 [ Fri Oct 16, 2009 8:41 am ]
Not worried about the floatation as much as I am about the boat getting hooks in the bottom, I think that I will go the Lowe's or Home Depot route.
