Gator Glide
http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=49357
Author:  mucknaked [ Mon Jan 20, 2014 8:06 am ]
Post subject:  Gator Glide
I have a 17x50. How much?
Author:  msm8281 [ Mon Jan 20, 2014 8:11 am ]
Post subject:  Re: Gator Glide
I used 1/2 gal of base and 1/2 gal of g4 and had plenty to do an 18x52.
Author:  fowl habbit [ Mon Jan 20, 2014 8:48 am ]
Just did my boat last Thursday 1854 went all the way on the bottom and 4 inches up each side, I only used a half gallon, took about 5hrs but turned out amazing. $130.00 bucks I ordered it on Monday had it here Thursday. David was great to work with.. Just remember the thinner the better on each coat. I used the small 6 inch hot dog sized rollers and it went on easy and thin, I went with the just the G2 in olive and was very happy with the color
Author:  wade_660 [ Mon Jan 20, 2014 9:35 am ]
That stuff really does go a long ways. I did my 17x54 with G4 and I could have got by with a 1/2 gallon easy.
Author:  BlueShamu [ Mon Jan 20, 2014 2:02 pm ]
I did two boats, 1848 and 1854 with less than a gallon of G2. Got 5 coats on each. About 6-8" up each side of each boat.
Like David says...thin to win!
Sent using Morse Code from my not so smart phone.
Author:  jc [ Mon Jan 20, 2014 5:34 pm ]
Author:  ibfishin [ Mon Jan 20, 2014 7:49 pm ]
Mucknaked.... After you and I got done spinning my boat around in that cattail forest I was thinking a slick bottom coat would have made that job easier. If you decide to do it let me know. Sounds like a gallon will get both of our boats done.
What is the difference between G2 and G4?
Sent from my SCH-I545 using Tapatalk
Author:  wade_660 [ Mon Jan 20, 2014 8:08 pm ]
I was told that the G4 is a little tougher but not as slick as the G2. That's what I have (G4)
Author:  marsh mule [ Mon Jan 20, 2014 8:45 pm ]
Didn't know thin to win... But I did my 15' generously even up transom and sides, and let my lil boy do the sled and still had over half a gallon left, I got the gallon.
Tried to make a sharp turn yest after the hunt, ended up on the bank sideways.. But it was easy to push off ;)
Author:  Gameover [ Tue Jan 21, 2014 6:55 am ]
Go with G2 much slicker than the G4. The G4 is not nearly impressive as the G2
Author:  Curltail [ Tue Jan 21, 2014 3:27 pm ]
I did mine with 1/2 gallon G2. Got 4 coats easily. Had a little left over to do the layout boat.
Author:  mucknaked [ Wed Jan 22, 2014 6:01 am ]
How much for gallon? Also do will have to sand our hulls?
Author:  tb469 [ Wed Jan 22, 2014 6:19 am ]
It tells the price and how to apply it on the Gator Glide web page. I think he is over around Sebring or Lake Placid.
Author:  BlueShamu [ Wed Jan 22, 2014 7:55 am ]
Author:  Frog [ Wed Jan 22, 2014 1:37 pm ]
Author:  ibfishin [ Wed Jan 22, 2014 6:36 pm ]
Me, tb469, and mucknaked are in okeechobee. Istokpoga must be void of birds if you are headed to IPC. Istokpoga was the best back in the day. Haven't been on that lake in many years.
Author:  Frog [ Wed Jan 22, 2014 8:18 pm ]
Author:  Hernaja1 [ Thu Jan 23, 2014 2:10 pm ]
Quick question , can u put gator glide ontop of old gator glide ?
Author:  Frog [ Thu Jan 23, 2014 2:38 pm ]
Yes, I'd give it a very light sand and good wipe with acetone and roller on. Thin Thin Thin coats.
You should never have t strip GG! Ever!
Author:  Hernaja1 [ Thu Jan 23, 2014 5:03 pm ]
Ight, thanks man I appreciate it. I have green GG on there know. The GG on there know is pretty worn on the hull. Bout to repaint the boat kacky tan anyway. So just figured I'd cover the old GG with new tan GG. Thanks again
Author:  Frog [ Thu Jan 23, 2014 7:39 pm ]
Author:  Hernaja1 [ Fri Jan 24, 2014 11:38 pm ]
Thanks I realy like the new ( used ) rig. It's a lil heavy but I just hate to remove the hunting deck or back seats to reduce weight. I'll prolly remove all the foam out of it and move the gas tank to the front of the boat. I'm also putting a light bar on front ( prolly seelites) and maybe a winch. I'm also going to try that Sears workout mating that seems to be just as good as hydro turf . I think Repainting the boat and new GG will give the boat a newer appearance. I realy like how the boats set up and I appreciate the work the preveous owner put into it. I'd like to get the biggest and best of everything but I'm on a budget .
Author:  JIMMY W [ Sat Jan 25, 2014 10:42 am ]
Hey Frog,Lets say you do the bottom of boat and then about a week later you wanted to do the rake part that you didn't do when you did the bottom.Would you have to sand the gg that you just put on a week ago where they meet?Or would you just overlap it a little?somebody asked me that!
Author:  BlueShamu [ Sat Jan 25, 2014 3:25 pm ]
In a perfect world, I would feather the existing GG back an inch or two and gradually come up over the existing with each coat.
Author:  Frog [ Sun Jan 26, 2014 8:01 am ]
Author:  JIMMY W [ Sun Jan 26, 2014 8:53 am ]
tks guys
Author:  ibfishin [ Sun Jan 26, 2014 1:23 pm ]
Dave.... can GG be applied without flipping the boat. My boat is too damn heavy to flip. Thinking about just lifting it off of the trailer if that will work.
Author:  Gameover [ Sun Jan 26, 2014 1:48 pm ]
That's how most do it
Author:  Frog [ Sun Jan 26, 2014 3:38 pm ]
Author:  jc [ Sun Jan 26, 2014 5:18 pm ]
No problems applying from the bottom. the Gator Glide won't drip on you or anything. Only time I got any on me was when I was rolling back over it really fast and a few little specks flew off the roller. Very easy to apply.
