| New 16X44 Gator Trax Hybrid Rake http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=52039 |
Page 1 of 3 |
| Author: | schauv01 [ Thu Apr 03, 2014 3:26 pm ] |
| Post subject: | New 16X44 Gator Trax Hybrid Rake |
About to pull the trigger on a new Hybrid Rake 16x44 HD Gator Trax boat. It will be strictly a hunting boat with pop up blind and head covers. I'll let you know how it progresses... |
| Author: | Randy S [ Thu Apr 03, 2014 5:50 pm ] |
| Post subject: | Re: New 16X44 Gator Trax Hybrid Rake |
Nice looking layout. You and barnes are meticulous. 16' going to be enough? My last one was 16x44 GD and it worked well, but said I'd go longer on the next one. Presume you're venting the battery box? If you shim up the half box seat level with the catwalks, will it be to tall for comfort on long rides? |
| Author: | VooDoo Daddy [ Thu Apr 03, 2014 6:03 pm ] |
I bet you will like it. I have a 1754HD with the enclosed cat walks. If I buy again, I will go with 18 plus hunt deck. and of course the hybrid. I just wonder how 10 inches less on the width would be. I would also go a little longer would probably take a load better for not much more weight. Do you really want to go so narrow? |
| Author: | DeltaRunner [ Thu Apr 03, 2014 6:56 pm ] |
Looks good man. Only other thing I will say is I have a 1648 and when I finally get a custom built boat it will be at least 1748 if not 1848. Just saying. |
| Author: | MNGunner [ Thu Apr 03, 2014 7:01 pm ] |
What is your hunting load typically? How many guys? What motor? Will Gtrax build hunt decks open?? I mean without the inner piece welded to the front face and to the hull and stringers. That's one thing I really don't like about my boat! |
| Author: | 270Handiman [ Thu Apr 03, 2014 7:02 pm ] |
| Author: | schauv01 [ Thu Apr 03, 2014 7:12 pm ] |
Correct, total length will be 17'8". I removed the dimension lines for clarity. I have an 18x54 now (19'6" total length). It's too long for our makeshift launch and too long and too wide to traverse our narrow trenausses. I enjoyed my boat, and the room, just too big for the lease I'm in. Will be pushing it with a 35H w/ Mikuni, they're calling it a "44s". Not sure why. False transom is still closed off to rest of hull, it's just how they're placing the fuel tanks now. My lease doesn't allow a lot of guests, so I'm carrying myself and another most of the time, hence the smaller design. |
| Author: | Team Schmo [ Thu Apr 03, 2014 7:13 pm ] |
Great looking lay out.. Iam with others on length, it's always nice to have extra room if it suits your situation... |
| Author: | schauv01 [ Thu Apr 03, 2014 7:21 pm ] |
| Author: | VooDoo Daddy [ Thu Apr 03, 2014 7:27 pm ] |
any news on when that H is going to be shipping? |
| Author: | fishnmoney [ Thu Apr 03, 2014 7:34 pm ] |
Boat looks good, what is the grab bar for behind the seat? When are the H's rolling out? |
| Author: | schauv01 [ Thu Apr 03, 2014 7:38 pm ] |
| Author: | MNGunner [ Thu Apr 03, 2014 7:40 pm ] |
| Author: | schauv01 [ Thu Apr 03, 2014 7:44 pm ] |
| Author: | MNGunner [ Thu Apr 03, 2014 7:47 pm ] |
| Author: | The Hairy Coot [ Thu Apr 03, 2014 9:17 pm ] |
Can't wait to hunt out of her Sent from my iPad using Tapatalk HD |
| Author: | Pete14 [ Thu Apr 03, 2014 9:37 pm ] |
| Author: | schauv01 [ Thu Apr 03, 2014 11:40 pm ] |
| Author: | The Hairy Coot [ Fri Apr 04, 2014 7:50 pm ] |
Those colors look pretty good. Sent from my iPhone using Tapatalk - |
| Author: | mud slinger 69 [ Sat Apr 05, 2014 6:21 am ] |
I like the new colors they whould work good here. Going to paint mine like that this year. |
| Author: | MNGunner [ Sat Apr 05, 2014 7:39 am ] |
| Author: | schauv01 [ Sun Apr 06, 2014 7:28 am ] |
Yeah, same here. The needle grass at my lease is dead 75% of the time. The only real time it's green is during teal season. And all I need to get teal to land is a kiddie pool and two yellow rubber duckie decoys, so the brown grass up against the green back drop doesn't matter much. |
| Author: | OwenDickeson [ Sun Apr 06, 2014 5:20 pm ] |
I like that grass pattern alot more than the all terrain one. That size boat should be just fine for 2-3 people. |
| Author: | schauv01 [ Mon Apr 07, 2014 4:37 pm ] |
Pulled the trigger on her today! My boat that is..... |
| Author: | schauv01 [ Tue Apr 08, 2014 12:21 pm ] |
Any idea what this rig is going to perform like speed-wise with a Stock 35 + Mikuni? From what I've read, looks like 26-27 light loaded and 23-24 heavy? Sent from my iPad using Tapatalk HD |
| Author: | BoatDR [ Tue Apr 08, 2014 12:38 pm ] |
The boat that I run on the lease next to your is a standard sided 1844 (no huntdeck) which I would say is about 100-125 lbs lighter than the boat you have specked out, and it runs those exact speeds with a dead stock motor. I would think that with a Mikuni and exhaust you should run slightly better than that. Although depending on how your boat comes out, in about 2 months I'm about 99% sure that I'll be getting a new "demo" boat set up pretty damn close to what you are getting. |
| Author: | barnes_53 [ Tue Apr 08, 2014 12:48 pm ] |
| Author: | The Hairy Coot [ Tue Apr 15, 2014 10:24 pm ] |
When is the boat supposed to be ready? Sent from my iPhone using Tapatalk - |
| Author: | schauv01 [ Tue Apr 15, 2014 10:41 pm ] |
| Author: | schauv01 [ Thu Apr 17, 2014 7:32 pm ] |
| Author: | VooDoo Daddy [ Thu Apr 17, 2014 8:36 pm ] |
| Author: | MNGunner [ Fri Apr 18, 2014 6:44 am ] |
| Author: | schauv01 [ Fri Apr 18, 2014 7:31 am ] |
| Author: | schauv01 [ Sun Apr 20, 2014 9:51 pm ] |
Update: Going to change "outboard package" which is an extra longitudinal brace to a 3/16" bottom vs 1/8" Running a lot of stumps |
| Author: | schauv01 [ Tue Apr 29, 2014 9:47 pm ] |
So I bought a small sheet of 16 Ga Stainless to make my instrument panel with. Any idea where I can get 2" holes cleanly cut in the Stainless around Gonzales, LA area? That stuff is pretty thick. |
| Author: | The Hairy Coot [ Wed Apr 30, 2014 10:28 pm ] |
| Author: | schauv01 [ Thu May 01, 2014 6:41 pm ] |
| Author: | dillakilla12 [ Thu May 01, 2014 7:25 pm ] |
Paint job is sick! Sent from my SM-N900V using Tapatalk |
| Author: | BayouStateHunter [ Thu May 01, 2014 7:29 pm ] |
I really like the paint. With a couple of green grass blades added, I would get that when I'm ready for a new look. |
| Author: | The Hairy Coot [ Thu May 01, 2014 7:44 pm ] |
My green is faded - I'm repainting with this new color scheme.... Sent from my iPad using Tapatalk HD |
| Page 1 of 3 | All times are UTC - 6 hours |
