It is currently Mon Dec 15, 2025 2:00 am
Reply to topic  [ 9 posts ]
 35 GDSD speeds
Post 35 GDSD speeds
I'm looking into buying a new MM, I do not really feel like spending 7500$ on a new GTR, or Mud Buddy, and I do not really want a PD because of gears (not knocking PD just don't want gears). That's why I'm looking at the 35 GDSD. If I go this route what speeds should I expect with and without a load. I will be putting this on the back of a 1650 Xpress.
Sat May 03, 2014 8:31 pm
Post Re: 35 GDSD speeds
I'm about to get one also, used but with under 15 hours so fairly new.. Ill be interested in the results
Sat May 03, 2014 9:05 pm
On the right boat you could see 30+. But thats on a true mud hull. Doubt you will see that on the express. But I could be wrong.
1648 GDSD 27 GDSD
Sat May 03, 2014 9:14 pm
Yea I know.. Wish I would've bought one in the first place! Any guess on what speeds I should somewhere expect?
Sat May 03, 2014 9:28 pm
I run one on an 1848 go devil surface drive boat. I bump 30 at times but mostly sit around 29.2 with 1 person, ice chest, couple batteries, tools, trolling motor etc.
It will push that 1650 express 30 for sure.
40HP Gatortail
Sat May 03, 2014 9:30 pm
Call CoCo and tell him exactly what you run in and what boat you have. He will put the correct trim tabs on that motor for your boat. Some boats need bigger trim tabs installed on the motor. I gave another member that same advice and he is loving life now. Coco set him up with bigger tabs and had the motor to him quickly. He was able to install the motor and go.
40HP Gatortail
Sat May 03, 2014 9:35 pm
I think he will have a problem with the bow bouncing.
1648 GDSD 27 GDSD
Sat May 03, 2014 9:37 pm
40HP Gatortail
Sat May 03, 2014 9:43 pm
Using Tapatalk
Sun May 04, 2014 6:49 am
