It is currently Wed Dec 17, 2025 10:35 am
Reply to topic  [ 11 posts ]
 Polymer bottom
Post Polymer bottom
Anybody running this or had any experience with it. i was looking around and saw it and was pretty interested. does it work??
What is THAT????? Aw Hell Ground Check IT!!!!!
Tue Feb 03, 2009 1:12 am
Post Re: Polymer bottom
See post labeled - EVIL GENIUS
Eat - Sleep - Hunt ! ! !
Tue Feb 03, 2009 3:29 am
WC Custom 1854
Tue Feb 03, 2009 7:11 am
It's in the Duck Blind Forum
Freedom It Wasn't Free!!!
It Was Won!!!
Enjoy It!!!
The more you try to teach a stupid person something the dumber you get!!!
Tue Feb 03, 2009 7:19 am
On boats, polymer and UHMW is the same. Its basically an engineered plastic.
I have it on my boat and i like it. I run in some rocks so it saves my hull. It also helps in veggies, sand and mud. To put it in perspective.... Its like using ky as opposed to not using ky....
Thats all.
Tue Feb 03, 2009 11:34 am
After riding in Flash's 1860 with UHMW.I will say it helps.We slid that boat across sand bars with ease.Some bars had no water on them others had a inch.We beached it one day and i was praying he had a winch.With 124 decoys and a 4 man heavy hunting load.The boat slid off without even straing.The ground was so hard we never left foot prints.
Tue Feb 03, 2009 11:58 am
So what's the approximate cost of this stuff? Any others besides EVT out there putting it on????
WC Custom 1854
Tue Feb 03, 2009 1:27 pm
I think I have around $1200 in mine. Drake 1 on here is the man to talk to. Like Coastal said...... IT WORKS!
Tue Feb 03, 2009 6:45 pm
I've been searching for this stuff online and i can't find what you are talking about. Can anyone post a link or have a site to find this miracle "KY"!!! ;) Chopper
Tue Feb 03, 2009 9:14 pm
One thing to consider is that once it's on it's on. It's worth spending a little extra to make sure it's done right and someone with a track record performs it. In my case I had it done by a local guy that has experience with it but the workmanship was sub-par. Now, after crushing ice and breaking ice slabs with the hull (in many cases right where the uhmw ended on the bow) it has started to peel. So lessons learned is get it done right and carry it as far up the bow as possible...if you hit high rocks (in current w/o reverse, it will happen) and ice it will be worth the extra foot or two.
That said, if one can recomend a good adhesive to attempt a repair, please let me know.
Sun Feb 08, 2009 5:41 pm
Should have also said I wouldn't run the sections of river I do without it. The damage it has prevented on hull is amazing and certainly worth the cost. Welding to repair the holes and scars would get expensive.
Sun Feb 08, 2009 5:43 pm
