It is currently Tue Mar 17, 2026 5:49 am
Reply to topic  [ 24 posts ]
 Perfect hull for a 27PD?
Post Perfect hull for a 27PD?
I have a short shaft 27PD motor and am looking to upgrade from my existing 1648 0.080 hull. I was looking to do a 1648 or 1748 in 0.125", completely open floor plan with one small box with seat base for the driver. Any and all ideas are appreciated. This is going to be my only boat build and I want to get it right the first time (or as close as I can to right). The Gator-tail base model 1648 is pretty darn close to what I want, but they are all tall transom boats.
I have a list of questions:
-What is the best type of chine to have with this boat/motor setup? Rounded, square, ect??
-Is 1648 or 1748 the best size hull for the 27PD? (I don't want/need an 18 foot boat, I need something somewhat light and easy to hide).
-Can I get away with 0.100" on the hull and still be durable enough to jump beaver dams to save some weight?
List of builders or ready made boats that you would recommend?
Tue Sep 16, 2014 12:53 pm
Post Re: Perfect hull for a 27PD?
If you can keep the weight down, that 27 will do fine.
What do you plan to do with the boat?
What is your typical load?
What type of areas do you run?
How long do you plan to keep it?
Do you plan on getting a big block motor down the road?
Budget?
37 PD EFI FPR 18x48 Tiller
SOLD -- 27 PD FPR 16x36 Skiff
Tue Sep 16, 2014 1:09 pm
I have .100 1744 tapred chine with a 23. I would say boat is about perfect size for a smaller Sd. My next boat will be 3/16 bottom as the .100 has dents from slowly rolling over stumps and hitting rocks. I wouldn't mind sacrificing a mph or 2 for something that wont dent easily. I wouldnt want to jump beaver dams with my boat. .100 is great for muddy rivers and marshes but i would go heavier.
Tue Sep 16, 2014 1:11 pm
We don't have mud like yall have in LA, but we hunt some very shallow areas with muddy bottoms, have to regularly jump small beaver dams, the occasional stump. My 0.080 hull has held up to the abuse for 4 years, but its getting trashed pretty bad at this point.
If I were to upgrade motors it would be to the EFI 27PD.
Tue Sep 16, 2014 1:29 pm
Tue Sep 16, 2014 1:32 pm
I loved my kohler and she was quick behind my 1636 skiff. If I would do it again, 1740 or 1742 with a 3/16 bottom, square chine, open layout.
Tue Sep 16, 2014 2:04 pm
Is there a big difference between the square or rounded chine?
Wed Sep 17, 2014 1:23 pm
Square chines are faster and draft less but they tend to slide more. On a narrow hull, it is easier to shift your weight to get a hull to bite in turns. They will all slide in the shallows.
Wed Sep 17, 2014 1:40 pm
Go no smaller than 18x42, You will want a 36 one day.
Wed Sep 17, 2014 4:11 pm
I already have a 18' center console with outboard boat for fishing. I would like to stay with a smaller boat that is easier to hide and maneuver in tight areas.
Wed Sep 17, 2014 6:19 pm
I've seen one that ran really well on a 1738 Geaux custom. They aren't in business anymore. But it was a pretty barebones 1/8, 1 piece, round chine hull.
Wed Sep 17, 2014 6:55 pm
What about a 1656 go-devil hull?
Thu Sep 18, 2014 4:37 pm
I can put my 1744 EVERYWHERE I put my 1448 dont fear a longer boat you will be surprised. Dont go shorter than 16'
Thu Sep 18, 2014 9:20 pm
Fri Sep 19, 2014 2:59 am
So where to get a 1648 0.125" hull? Just a plain-jane hull.
Wed Sep 24, 2014 6:40 am
Wed Sep 24, 2014 6:44 am
I don't care if its custom or not, I just want a simple/open 0.125" 1648.
I sent Dfou a msg this morning. I'll msg those others you mentioned.
Thank you.
Wed Sep 24, 2014 7:05 am
Go devil and gatortrax wouldn't be bad hulls to have either if you didn't want to go custom.
Well if you getting a pd I would see about a pd hull.
Sent from my beeper
Wed Sep 24, 2014 7:10 am
I already have a 27PD and a big (too big for what I hunt) go-devil hull (and a light weldbuilt hull). Just wanting to get back to a skinny-er/lighter boat.
Wed Sep 24, 2014 7:20 am
Go-Devil hull just weighs too much for my little PD and is hard to hide due to the width. Also want more open room.
Wed Sep 24, 2014 7:21 am
The weldbuilt is just 0.080 and not durable enough.
Wed Sep 24, 2014 7:22 am
Well a pd hull is made for a pd so it might be a perfect match.
Sent from my beeper
Wed Sep 24, 2014 7:24 am
I can get the same size/options from Prodigy cheaper than the PD hull. I like the PD hulls, but their prices are a good bit higher than most for the same options. And if you price it from Extreme Metal Fab its even cheaper. Guess I am looking for the best price on the hull and I would rather throw the "little man" a bone if I can over the big name boats.
Wed Sep 24, 2014 7:31 am
why don't you just keep the new hull you got and just try it out! never know you might like the extra room. :lol:
Mon Sep 29, 2014 11:04 am
