| opinions on construction http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=5862 |
| Author: | wal1809 [ Thu Nov 05, 2009 12:46 pm ] |
| Post subject: | opinions on construction |
Alright men, I have decided to sell my fishing boat and keep the mud boat. To do that I am going to have to do some changes to the mud boat. I have decided to drop a decent amount of coin to make a front upper/removable deck with lights for bow fishing and foundering, a cast deck for sight casting reds and a rear poling platform. So the thought process is to creat something that does not affect anything already in place. In other words I don't want to give up on tiller swing to put a poling platform in. Traditional platforms are 4 legged. I am making one which is two legged basing it off of the transom. So your opinions on gussets would be appreciated. Here is a crude design sketch to give you the idea of what I am working with. |
| Author: | Wendlwacker [ Thu Nov 05, 2009 3:22 pm ] |
| Post subject: | Re: opinions on construction |
i would say the lower design would be stronger |
| Author: | quackconsumer [ Thu Nov 05, 2009 3:46 pm ] |
I agree da lower design would be stronger. But I hope you're not a big ole boy or you're gonna get a wet azz when dat thing gives. |
| Author: | richardb [ Thu Nov 05, 2009 4:00 pm ] |
X2 Lower design looks stronger |
| Author: | Tenpoint [ Thu Nov 05, 2009 5:37 pm ] |
Bottom design does look better. Might want to add one more pole to the front, coming straight down to the boat. If not ya might have the scissor effect and come tumblin down. |
| Author: | wal1809 [ Thu Nov 05, 2009 5:53 pm ] |
Don't want no wet ass for sure. I am 300 pounds so it has to be made strong. I got home a minute ago and looked at it. The two vertical tubes will be made out of 2 inch by 1/4 inch aluminum. I recon that ought to hold my big arse. Anybody here an aluminum guy that can find out the bend strength of 2"x1/4" aluminum tube? |
| Author: | TXSHOCKWAVE [ Thu Nov 05, 2009 7:35 pm ] |
You should bring the boat to my shop. I work for boatright and we make plat forms like you are wanting. www.boatrightmarine.com |
| Author: | wal1809 [ Fri Nov 06, 2009 6:40 am ] |
Hello Shockwave, I forgot all about Boatright's design. I made a blind for my buds 24 foot boatright and the rear push tower is just what I m looking for. I can't believe I forgot that design. It is perfect. I just have to run the vertical at the same angle as the transom so as not to interfere with the tiller handle. I can turn the moor far enough where it is vertical above the right rear corner of the boat or the left rear corner of the boat. Where is your shop? |
| Author: | indybill [ Fri Nov 06, 2009 6:48 am ] |
Txshockwave does GREAT work. Shop is across from Ellington airfield on Hwy 3. He has done my custom work. |
| Author: | TXSHOCKWAVE [ Fri Nov 06, 2009 8:06 am ] |
just give us a call 281 992 4554 |
