| Depth finder transducer mounting http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=58973 |
| Author: | Ridendirty211 [ Sun Dec 28, 2014 8:23 pm ] |
| Post subject: | Depth finder transducer mounting |
Need some ideas for mounting a transducer on the back of my 1752 with a hint deck. Has anyone made a removable mount of any sort? I run mud and timber all the time and don't want that thing to get ripped off or destroyed. I would like to have the depth finder for when I fish. I'm out of ideas. Thanks in advance. |
| Author: | rob_rides_03 [ Sun Dec 28, 2014 8:54 pm ] |
| Post subject: | Re: Depth finder transducer mounting |
They make ones that mount to the floor of the boat that penetrate through the hull so there is no transducer on the outside. It's called a alumaducer |
| Author: | 4Cody4 [ Sun Dec 28, 2014 8:55 pm ] |
Or check with WestendAngler. He has his on a removable ram mount. |
| Author: | JLACOUR [ Sun Dec 28, 2014 9:01 pm ] |
I modified the bracket from bass pro. That is in the down position. I stole the idea from someone else on here. |
| Author: | 270Handiman [ Sun Dec 28, 2014 10:28 pm ] |
Gator Trax makes one that slides also. |
| Author: | Ridendirty211 [ Mon Dec 29, 2014 9:00 am ] |
That sliding mount is a damn good idea. Thanks for the info guys. |
| Author: | deerman101 [ Tue Dec 30, 2014 9:58 am ] |
This is the gator trax style. I ordered the material yesterday to make it, cost under $20 and just going to give my welder a 6 pack for his work. |
| Author: | TheIcon44 [ Tue Dec 30, 2014 10:25 am ] |
Here is the ram mount |
| Author: | deerman101 [ Tue Dec 30, 2014 10:29 am ] |
| Author: | TheIcon44 [ Tue Dec 30, 2014 12:46 pm ] |
It moves a little bit, but I haven't had any problems with it. |
| Author: | Maclavin [ Thu Jan 01, 2015 1:23 pm ] |
I have the one from Gatortrax. Had a local welder put it on. Works great.image.jpg |
| Author: | LB200 [ Thu Jan 01, 2015 4:42 pm ] |
Glad this thread started. I just got a new GPS/depth finder for Christmas and will be doing this same thing. I would like one that is removable because I only fish with it on odd occasions |
| Author: | SETx Longtail [ Thu Jan 01, 2015 5:14 pm ] |
I'm a fan of the alumaducer for the simple reason that Id forget to pick up one of those sliding mounts and drag it off for sure lol. |
| Author: | btmannin [ Thu Jan 01, 2015 5:42 pm ] |
| Author: | Maclavin [ Thu Jan 01, 2015 6:20 pm ] |
| Author: | SETx Longtail [ Thu Jan 01, 2015 10:09 pm ] |
We ran one on an Alumacraft bass boat. It's mounted at the back of the boat close to the transom. Boat is .100ga |
| Author: | meterman3 [ Fri Jan 02, 2015 9:45 pm ] |
Way I found my spot put 2" water in boat then transducer in bag fill water zip tye then weight it down move to best spot done 3 boats with stock transducer Mac |
| Author: | 4Cody4 [ Fri Jan 02, 2015 10:57 pm ] |
What does the water do? |
| Author: | rob_E [ Sat Jan 03, 2015 7:51 am ] |
I did the water in the boat installing mine also. I think the water mimics the epoxy you use to put it down. When you buy one it comes with instructions. And that's how they recommend you find the sweet spot before mounting it permanently. |
| Author: | swampbilly [ Tue Jan 06, 2015 10:01 am ] |
Here is one pokey79 made for me. ImageUploadedByTapatalk1420560045.795312.jpg ImageUploadedByTapatalk1420560054.577032.jpg No welding required. |
| Author: | swampbilly [ Tue Jan 06, 2015 10:02 am ] |
ImageUploadedByTapatalk1420560161.260397.jpgImageUploadedByTapatalk1420560169.110270.jpg |
| Author: | swampbilly [ Tue Jan 06, 2015 10:04 am ] |
ImageUploadedByTapatalk1420560240.019831.jpg Mine isn't a hunt deck, that's just showing it next to his boat. When I get it out the mail and mount it I'll add some pics of it. |
| Author: | quack-quack [ Tue Jan 06, 2015 4:17 pm ] |
Not to hijack here, but do yall connect your GPS straight to the battery or to a switch panel? |
| Author: | JLACOUR [ Tue Jan 06, 2015 4:20 pm ] |
Straight with an in line fuse |
| Author: | rob_E [ Tue Jan 06, 2015 5:13 pm ] |
| Author: | LB200 [ Tue Jan 06, 2015 5:17 pm ] |
I put mine through the switch panel and I am already thinking about changing it. |
| Author: | 270Handiman [ Tue Jan 06, 2015 8:37 pm ] |
I power mine with a 12v plug into one of my 12v outlets, which are powered from the switch panel. |
| Author: | Ridendirty211 [ Fri Jan 16, 2015 4:07 pm ] |
Thanks for all the help guys. I made one out of aluminum that slides up when I'm running the marsh and it slides down and pins when I'm fishing. Works perfect. Gave me a excuse to mess with the new spool gun too. |
| Author: | big country [ Sun Dec 20, 2015 9:25 pm ] |
http://www.fishfindermounts.com/#!produ ... ks-&-boats Sent from my iPhone using Tapatalk |
