| Whats paint to use http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=59707 |
| Author: | genson [ Thu Jan 29, 2015 7:31 pm ] |
| Post subject: | Whats paint to use |
Repainting my boat whats the best paint for the price |
| Author: | DeltaRunner [ Thu Jan 29, 2015 7:39 pm ] |
| Post subject: | Re: Whats paint to use |
If you want it to last, you will have as much or more money in primer. I used XIM 400. It comes in a rattle can at $18 a pop. I used 6 cans on my 1648 (inside and out) For the base coat I used Shipendeck. I want to say it was around $70 per qt. |
| Author: | cb5331 [ Thu Jan 29, 2015 7:40 pm ] |
If you'll strip it down to bare aluminum, duralux aluminum boat paint is hard to beat for the money. |
| Author: | duckduckboom [ Thu Jan 29, 2015 7:53 pm ] |
I don't believe you really need to strip it to aluminum. Just wash it real good with a heavy detergent, wipe with mineral spirits and then paint away |
| Author: | cb5331 [ Thu Jan 29, 2015 7:57 pm ] |
I just know that shit sticks well to bare aluminum. Wasn't sure if it sticks well to other paint. |
| Author: | tyler_johnson [ Thu Jan 29, 2015 8:05 pm ] |
The other duralux paint will stick to damn near anything, part of my fuel lines are still brown. . The green bare aluminum is great for bare aluminum. All I did with mine was use a scotch Brite pad (dish washing kind) to smooth it down and scuff up, then wiped down with rubbing alcohol, took a good beating this year in the timber in Arkansas and surprised me! |
| Author: | duckduckboom [ Thu Jan 29, 2015 8:26 pm ] |
| Author: | genson [ Thu Jan 29, 2015 8:27 pm ] |
Sanded it with 320 cause someone put tiger stripes on it that was thick but washed with steam and blue magic ... I ve been looking at the duralux didnt no how good it holds up |
| Author: | duckduckboom [ Thu Jan 29, 2015 8:28 pm ] |
very well |
| Author: | cb5331 [ Thu Jan 29, 2015 8:30 pm ] |
| Author: | duckduckboom [ Thu Jan 29, 2015 8:35 pm ] |
it will stick and i have used it. if you use paint thinner it will actually make it somewhat tacky and other paints will stick. as long as you are not mixing arcylics, oils and latex you should be fine |
| Author: | duckduckboom [ Thu Jan 29, 2015 8:37 pm ] |
http://www.homedepot.com/p/Duralux-Mari ... /205128316 this is the kinda with primer but you can get it at galvez hardware for cheaper |
| Author: | cb5331 [ Thu Jan 29, 2015 8:45 pm ] |
| Author: | duckduckboom [ Thu Jan 29, 2015 8:46 pm ] |
same diffrence |
| Author: | cb5331 [ Thu Jan 29, 2015 8:46 pm ] |
| Author: | deadbird8 [ Fri Jan 30, 2015 5:06 am ] |
| Author: | duckduckboom [ Fri Jan 30, 2015 6:17 am ] |
I have heard vinegar too just never used myself |
| Author: | MNGunner [ Fri Jan 30, 2015 8:07 am ] |
Parker duck boat paint |
| Author: | jldsc [ Fri Jan 30, 2015 8:24 am ] |
I would never just clean and paint over paint!! need to scuff it at a minimum... I use a DA on all the boats ive done with 180-320 grit...about the last 5-6 boats ive done I have used BLP Mobil marine paint...Its been holding up very well...Ive also even sprayed it over u-pol raptor spray in bedliner in a boat and it adhered very good!! I find acetone is a very good greese/wax remover to prep before paint. Sent from my iPhone using Tapatalk |
| Author: | Howdy [ Fri Jan 30, 2015 8:51 am ] |
I have used sems self etching primer and parkers duck boat paint |
| Author: | baron von [ Fri Jan 30, 2015 10:28 am ] |
denatured alcohol, available in the paint aisle works very well and no residue. Acetone works very good on the stubborn oil, grease and blood stains. get a in-expensive HVLP paint gun it will apply a more durable and even finish than rattle cans, and it's just fun to use. 41Z7GNFV4HL.jpg |
| Author: | baron von [ Fri Jan 30, 2015 10:32 am ] |
a lot of us use Parker up here, it very easy to work with, very durable and forgiving of amature painters (like me) mistakes http://www.parkercoatings.com/decoy.html |
| Author: | med [ Fri Jan 30, 2015 10:41 am ] |
Yhry have colors other than green in the duralux? Sent from my XT907 using Tapatalk 2 |
| Author: | tyler_johnson [ Fri Jan 30, 2015 10:46 am ] |
Yes they have a few other colors. My base is dead grass green which is very close to the Gator Tail base color. |
| Author: | baron von [ Fri Jan 30, 2015 10:55 am ] |
| Author: | Frog [ Fri Jan 30, 2015 11:08 am ] |
Don't paint the bottom unless using GatorGlide. Your vinegar should be diluted with water 40% vinegar. Not a bad idea to neutralize with baking soda and water after. |
| Author: | baron von [ Fri Jan 30, 2015 11:20 am ] |
Whatever paint you choose the main item in all these posts is preparation. You will save yourself a lot grief by spending a little (or a lot) of time preparing the surface for paint. Bare aluminum, is ideal but not essential to completing your task. But preparing is - cleaning, scuffing (light sanding) will ensure your paint lives up to its full potential. WP_20140712_19_44_48_Smart[1].jpg Three coats of Parker Marsh Grass - no primer and to date no peeling or adverse effects of weather, weeds, or exposure WP_20140718_10_30_26_Smart[1].jpg |
| Author: | Frog [ Fri Jan 30, 2015 11:27 am ] |
| Author: | genson [ Fri Jan 30, 2015 1:33 pm ] |
Who all carrirs duralux besides homedepot duralux website is messed up wont let ya locate a dealer |
| Author: | tyler_johnson [ Fri Jan 30, 2015 1:51 pm ] |
EBAY!!! Thats where I got my gallon! it was like $46.00 with free shipping! |
| Author: | cb5331 [ Fri Jan 30, 2015 1:53 pm ] |
I've seen the cheaper paints on ebay for that price, but not the "aluminum boat paint". If you had a color option, it ain't the right stuff. |
| Author: | tyler_johnson [ Fri Jan 30, 2015 1:57 pm ] |
No it was the dead grass green, the bare aluminum green is like $76 |
| Author: | cb5331 [ Fri Jan 30, 2015 2:20 pm ] |
| Author: | idabilly [ Sun Feb 01, 2015 8:53 am ] |
Many of the boat manufacturers use Sherwin-Williams KEM 400, flatted down to 3-5% sheen. I repainted my boat with that. Must be sprayed on...I used HVLP. Have heard good stuff about boat paint sold by Lock Stock and Barrel. Lots of boats wearing that stuff. |
