It is currently Tue Jul 08, 2025 2:11 pm
Reply to topic  [ 11 posts ]
 gtr on go devil boat
Post gtr on go devil boat
I just re-powered me 18x44 go devil boat with a gtr35. this is my first surface drive motor. My question is on the gd boat it seems to run heavy in the rear and there is a large amount of torque on the motor to the point it is uncomfortable to drive. Is this normal for this set-up being the boat is narrow with round chines?
Wed Dec 09, 2009 1:26 am
Post Re: gtr on go devil boat
did you mount your engine dead center? you can shift it away from you about an inche or two that should help with some of the torque
Wed Dec 09, 2009 2:22 am
Wed Dec 09, 2009 6:23 am
it's gonna "squat" because of the rounded chines. I tried a 23 GTR on my 16x38 GD boat and it ran horribly. you can put wedges underneath or some wings on the side to help it plane out better but at dead stop it ain't gonna sit flat. Kyle wanted to put wedges on the bottom of my boat if i went with the motor but the more i though about it, that sorta defeated the purpose of having a slick bottom with rounded chines.
"I have been blessed with many things in this life, an arm like a rocket, a c*ck like a Burmese Python and a mind of a f*ckin scientist."
-Kenny F*ckin Powers
Gator Trax 3-Man Gatorhide with a Mud Buddy HD Sport 5000
Large Big Green Egg with rounded chines
Wed Dec 09, 2009 2:30 pm
How old is the boat, and have you pulled the waterlogged foam out of the floor? I'm running a 36pd on a 1844 and when compared to running it on a 52" tapered chine there was only a slight difference in draft.
Wed Dec 09, 2009 7:35 pm
As others have said, I have found that load positioning with a GTR can really make a difference as to driveability.
Wed Dec 09, 2009 7:50 pm
Thanks for the suggestions...i figured that there was an easy fix i just didn't want to screw with anything till i got some advice. As far as the foam in the bottom i have not checked it but i do know that the boat is heavy. The bottom floor is riveted down, how did u re-attach it after pulling it?
Wed Dec 09, 2009 7:53 pm
Just drill the old rivets out with a 3/16" bit, remove the foam, and replace the rivets. I got big head replacement rivets from GD. And I have also used regular ones from Lowes or Home Depot. And they worked fine.
P.S. I put wedges on my boat and it stopped the porpoising and it rides much flatter. The times I have had to push backwards off the bank, they did not seem to hurt anything.
35 hp CDI MB HD Sport pushing a 17'6" Uncle J custom bateau
Fri Dec 11, 2009 3:36 pm
Thanks for the info rebbeer....luckily i dont have a prob with it porpoising..it just feels heavy in the water...prob all the waterlogged foam..
Fri Dec 11, 2009 8:57 pm
Go Devil will sell you new foam and rivets for about 75.00
new the foam only weighs about 10 pounds...
Without the foam the floor will be soft and the bottom more
likely to suffer longitudinal "hooks" or dents between the runners....
Eat - Sleep - Hunt ! ! !
Fri Dec 11, 2009 10:37 pm
One of my buds has a gatortrax boat with a gt..that thing whoops you worse than a big hp longtail
Bobcat Mag 1 Pirogue with paddle
Brother Breaux 16x36 with a 23 GDLT
Tue Dec 15, 2009 11:46 am
Users browsing this forum: No registered users and 128 guests
