Prodigy Blind Pics http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=63945 |
Author: | mikecatt13 [ Wed Sep 30, 2015 9:49 am ] |
Post subject: | Prodigy Blind Pics |
Does anyone have pics of the inside of their prodigy blind while its up? Going to install mine and some reference pics would be helpful. Mounting to the boat will be no problem, but i know there are support ropes etc that would be nice to see. Also how the shaggy panels etc are on the frame. Thanks |
Author: | mikecatt13 [ Thu Oct 01, 2015 5:00 pm ] |
Post subject: | Re: Prodigy Blind Pics |
Nobody? |
Author: | DmaxHunter [ Thu Oct 01, 2015 5:36 pm ] |
I use these to attach ss clips using paracord to 1/2 rigid conduit frame. Criss cross lines, I don't have inside picture sorry. |
Author: | DmaxHunter [ Thu Oct 01, 2015 5:44 pm ] |
Author: | LB200 [ Thu Oct 01, 2015 6:40 pm ] |
I will try to get you some but I have to get them off my phone and into my I pad first |
Author: | LB200 [ Thu Oct 01, 2015 6:53 pm ] |
The "ropes" connect to a Bimini top loop on the boat with a dog leash snap and ar simply tied to the tubing. The center "rope" is actually two, one tied with a loop and the other tied to tubing with another dog leash snap. When hooked to the boat and raised up into position you clip the two pieces together in the center. The side ropes keep it from falling in either direction. I add a piece of 3/4" pvc pipe at the bottom, zip tied in, to be able to roll it all up neatly for travel |
Author: | LB200 [ Thu Oct 01, 2015 6:56 pm ] |
I use a light "tank netting" and zip tie it to the tubing. You zip tie additional stuff to the tank netting |
Author: | mikecatt13 [ Thu Oct 01, 2015 8:16 pm ] |
Thanks guys, helps a ton! Will save me a lot of time being as I'm behind the 8 ball on this! Nice gun choice Dmax |
Author: | DmaxHunter [ Fri Oct 02, 2015 4:31 am ] |
Thanks, this will be season four for the extreme, and can't say enough good things about that gun. One thing I did with my blind use a expensive thick tarp, helps block wind and keep the heat from the portable propane heater in the blind. |
Author: | mikecatt13 [ Fri Oct 02, 2015 6:28 am ] |
Author: | brickgw [ Fri Oct 02, 2015 9:30 am ] |
Author: | LB200 [ Fri Oct 02, 2015 9:51 am ] |
We can use tank netting because we don't ever need heaters lol. If we hit 30 degrees it is pretty unusual. Beretta's are the real deal. I love my Extreme. It is the smoothest shooting gun I have ever used, including all my other Beretta's |
