It is currently Sun Feb 15, 2026 3:26 am
Reply to topic  [ 7 posts ]
 Prodigy custom blind?
Post Prodigy custom blind?
I was looking at how its made but Im trying to see how it pivots and stays upright.Can someone chime in that has one how it holds together?
Wed Nov 25, 2015 8:44 pm
Post Re: Prodigy custom blind?
It has two ropes that you tie to each side and attach them with the clips that Chad gives you. Do it for the front and the back on each side
Thu Nov 26, 2015 3:37 pm
Ok thanks,but im still wondering how does it pivot with the bolts.Im not very mechnically inclined so can you post any photos at various angles and whst size bolts and screws that he uses and the measurement of the spacing between each bolt from the from the front and the back? Thanks!
Thu Nov 26, 2015 4:46 pm
The frame pieces he gives you are about 9-10 foot (guesstimate) and you can cut each one the custom fit your boat. They also come with a sleeve for each side so you can put em together. It just bolts through the bracket, through the frame, and out the other side with a lock nut that you screw down. Have no idea what the dimensions are on the bolts and screws. Don't have any pics on me of it right now but there's some on their Facebook page. If you go through their albums the ones that have a blind on them usually have a pic or two of the brackets or you can at least see them. Will try and get around to taking a pic tomorrow before work
Thu Nov 26, 2015 5:29 pm
Mine came from him already mounted to the boat.
Thu Nov 26, 2015 6:03 pm
When I picked mine up. Attached 1" nylon webbing to frame to hold in upright position.
1754 Prodigy pushed by a level 3 DPE Gen 4 37PD
Thu Nov 26, 2015 6:12 pm
This is my prodigy set up. I actually like it better because there is nothing on the front deck and it is easily removable in a couple minutes. The red is from a previous post showing where the ropes go that keep it in place
Thu Nov 26, 2015 6:37 pm
