It is currently Sat Jan 19, 2019 2:54 am
Reply to topic  [ 12 posts ]
 permanent gas tanks
Post permanent gas tanks
who all is running a permanent gas tank in their boat? I am planning to go from a 6 gal portable tank to a 16 gallon permanent tank installed under the front deck. What are the pros and cons of goingthis route?
thanks alot
Mon Feb 05, 2018 1:37 pm
Post Re: permanent gas tanks
Will your permanent tank be aluminum?
If you think about it, most people don't ever take their gas tank out of their boat.
I don't see any cons of a permanent tank besides if you have a leak in the tank or a fuel pickup issue.
dead animal wrote:
Giga, u need a fukin throat punch. if u want flotation, good for u, but don't ever, for 1 second of your miserable life, think u can tell me what to do.
whatever
Mon Feb 05, 2018 1:44 pm
the tank I have is poly, it is out of an old ski type boat.
Mon Feb 05, 2018 2:14 pm
I have 16 gallon permanent beneath my front deck - poly construction. Remote fuel gauge on my console. Wouldn't change a thing about it. Only con vs one six gallon and two five gallons...if you have to make long trips like I do, you can take out the extra cans once you get where you're going to lighten your load running around. You're still heavy with fuel once you make that 24 mile trip to the camp with the built in.
18' x 54" Uncle J Custom Center Console w/36 HP Prodrive - The FULL Story!
Backwater Performance Systems
Swamp Staff
WhoDat88 wrote:
Just think how much better MMT would be with out Dean as a member.
Mon Feb 05, 2018 3:32 pm
I got rid of the 6gal EPA balloons a while back and built a 17gal aluminum tank to go under the deck of my GD. Wouldn't have it any other way. Service the fuel filter/water separator yearly and roll on. If it sits like mine has recently, fill it up, and put fuel stabilizer in it. No worries. I seldom fill it all the way up but it's nice to have the fuel on board for my week long camping trips I get to take sometimes up the river.
-Custom pool noodle
-stage 4 water wings
Mon Feb 05, 2018 7:56 pm
I take my tank out every time. My permanent tank would always get water in it somehow so I switched to a plastic removable one and keep it in the garage.
Tue Feb 06, 2018 1:28 pm
Was it aluminum?
whatever
Tue Feb 06, 2018 1:35 pm
I built in a 12 gal tank into the bow of my 1648 Alumacraft. Just extended the deck enough to cover tank and installed a vented filler station. Really helped balance the boat, and at the same time moved rear bench seat 16" forward so I could stand behind it if needed.
Tue Feb 06, 2018 4:29 pm
14 gallon up front. Used as a step for the kids to get up on front deck.
?? HP Kawasaki Powered PD pushing a 1748 beyond the laws of physics
Wed Feb 07, 2018 5:25 am
20+ gal. in Center console and more than half is out front and used as a seat. Side fill mounted on side of console. Have fuel gage mounted in console.
Uncle J Custom - 19x54 CC Skiff w/35 GTR
Wed Feb 07, 2018 9:34 am
Thanks for the words of advice guys, i really appreciate it. Ill be installing a 16 gallon tank shortly.
Thu Feb 08, 2018 9:34 am
thanks alot
I have a 16 gallon permanent aluminum tank under my deck with a remote gas gauge. I have a black plastic gas cap on my deck tonthe gap. I love having it. The only con will be if you don’t use it enough the tank will sweat and get water in it. I use mine pretty often so my gas mostly stays fresh.
1848 modified V, 24 inch sides with hunt deck built by Rene Gros and painted and rigged by LA Boat Worx
37hp Boss Drive with the Anti-Tiller torque handle, Boat Doctor heads, Voodoo exhaust and a tuner
Thu Feb 08, 2018 11:09 pm
Users browsing this forum: No registered users and 15 guests
cron
