Pro drive & excel boat
http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=7303
Author:  oltcudown [ Sat Jan 23, 2010 7:50 am ]
Post subject:  Pro drive & excel boat
Found a very good deal on a sw1651 excel boat. How well do you guys think this boat will do with my 27 prodrive on it? Normal load is 2 guys(220 a piece) and about a dozen decoys. Btw motor is going to evt this summer for a little work.
Author:  balloon-knot [ Mon Jan 25, 2010 9:55 am ]
Post subject:  Re: Pro drive & excel boat
It should be a good boat. I am not sure on the transome angle, I seem to recall excel having less transome angle than the PD's like. Not that its a huge deal. Quick fix with some shims on the motor mount.
Author:  white cracker [ Mon Jan 25, 2010 2:22 pm ]
i have a sw17x54 with a 45hp mud buddy get about 20 with two people and 4 dozen decoys, excel boats dont turn that easy also alot of sliding
Author:  Gatorpoint [ Mon Jan 25, 2010 5:59 pm ]
Hizzoner on here has an 1851 with a 36. He should post on here, if not PM him. He has some experience with excel and prodrive combos.
Author:  Phathead [ Mon Jan 25, 2010 6:41 pm ]
White Cracker---you should be running high 20's with that load and a 45 hyper. Definitely not just 20mph. Something is not right with your setup or your engine. And yes, my Excel was a sliding son of a gun too.
Oltcudown--That 27 PD should do pretty well on the 1651 with the load you described. Probably a 20mph boat, maybe a little better. The excel hulls are overbuilt and tend to be heavy. If you add a 3rd man and gear it will be very noticeable. If possible, I would go with a 36 on that hull.
Author:  white cracker [ Mon Jan 25, 2010 8:17 pm ]
oh yeah i know somethings gotta be wrong i got a small prop on it and factory muffler, wonder if that could be part of the problem. and the next boat i buy is going to be gator trax
Author:  Hizzoner [ Mon Jan 25, 2010 8:37 pm ]
If I remember correctly, the 1651 is not designed for a mud motor. It is probably a .100 gauge hull and may have some cross bracing....not sure.
The 54" bottoms slide a whole lot more than the 51". I really like my 1851, but it really doesn't matter in this situation. The boat you are talking about, I believe, is a different animal in that it was designed to run with an outboard (I think).
I'm not as informed as I used to be :lol:
Author:  Gigafowl [ Mon Jan 25, 2010 9:19 pm ]
I believe he has the SW version....
http://www.excelboats.net/Shallow%20Water%20Series.html
The 17 inch - 17 degree transom is optimized for the MudBuddy
but the boat should be .100 gauge - slick semi-vee - tripple tapered chine
with longitudinal bracing....
We don't see many here in Texas --- let us know how she does solo
and loaded.....
Author:  oltcudown [ Tue Jan 26, 2010 7:42 am ]
you are correct gigafowl. Its the shallow water 1651, 20 in transom, and .125 gauge. Its not a semi-v, it's a flat with a pointed bow. Does anyone know what degree transom the pro drives perfer.
Author:  Short On Cache [ Tue Jan 26, 2010 9:53 am ]
I had an excel. Just my opinion, It was too heavy. Didnt perform slid like crazy and not nearly as tough as my Phowler. Just my .02
