It is currently Mon Dec 15, 2025 10:22 am
Reply to topic  [ 5 posts ]
 Aluminum Decking
Post Aluminum Decking
right now i've got an 8'x4' piece of plywood as a floor in my 1648. its got horizontal stringers. what gauge aluminum would i use, and about how much does a sheet that size weigh. is it worth the cost for the weight difference? im running a 27 kohler LT.
1648 w/ 27LT
Go Gators
Thu Feb 12, 2009 9:32 am
Post Re: Aluminum Decking
It wouldn't make that much of a difference from 1/2in plywood to 1/8in aluminum in a 4x8 piece. But having it seal welded where nothing could get under the floor may make a difference. I had a ton of mud and junk under my floor when I pulled up my plywood.
Thu Feb 12, 2009 9:45 am
SS is exactly rite !!!! Never put a floor in there that can't be removed ifin you use the BoatHull like alot of folks do !!!! I don't care who put it together ....... crap will git thar and mess with yore performace.
One mo thang !!!!! ~ When you git them big green blowflies 'round yore hull when it's just sittin' out in the yard ............ it's time 'fo a rinsein' !!
Thu Feb 12, 2009 8:01 pm
Replaced my wood floor with a 6x4 1/8 alum I got at a scrap yard for $100. Put foam on side wall opening to prevent stuff from falling under. So far so good, not the prettiest but it works and it's better than having the seat bases tear out of the wood floor :mrgreen:
Josh
"Grace calls us to change and then gives us the power to pull it off!"
Max Lucado
Fri Feb 20, 2009 11:18 am
Fri Feb 20, 2009 12:31 pm
