It is currently Tue Dec 23, 2025 1:48 am
[ 4 posts ] |
hoosierharvester
 charging issue
i have a 35 hp mudbuddy vangaurd hd sport ,im having a problem , i had to replace my voltage regulator last summer , i only have the night time nav lights and the motor ran off of my brand new battery ,well i also night fish and at the end of the night the battery was dead . it started the motor up but by the time i got back to the ramp i could tell by the nav lights that the battery was low so after i got the boat on the trailer i shut it off and tried to start it back up and it wouldnt even click now with the battery charger hooked to the boat it will start fine but the system wont go above twelve volts the regukator is not charging again so what would cause this concern could my clutch be drawing down the battery ???????
| Sun May 30, 2010 11:33 pm |
stumpgrinder
 Re: charging issue
Hard to troubleshoot through all that jibberish & speculation.
with a volt meter check...
1. battery voltage 2. battery voltage with motor running at idle 3. battery voltage with motor running at full rpms
Then come tell us what you find.
_________________ I'm your Huckleberry......... http://www.youtube.com/watch?v=XqVe3xG-wos
I am proud to be an American, I am glad that I am free... but right now I wish I was a dog, and Obama was a tree.
| Mon May 31, 2010 6:24 am |
drake1
 Re: charging issue
Motors were only designed to run at 3600 rpms. When running at 3800 plus the regulator could be charging to hot which could burn up the stator. Put a 25amp fuse on your regulator so the fuse blows rather than the stator.
| Mon May 31, 2010 2:51 pm |
quack addict
Joined: Tue Jan 13, 2009 5:44 pm Posts: 620 Location: Metairie, LA
 Re: charging issue
had the same problem with my MB. it was a loose wire at the alternator i think. i will find out exactly for you.
_________________ "I have been blessed with many things in this life, an arm like a rocket, a c*ck like a Burmese Python and a mind of a f*ckin scientist." -Kenny F*ckin Powers
Gator Trax 3-Man Gatorhide with a Mud Buddy HD Sport 5000
Large Big Green Egg with rounded chines
| Thu Jun 03, 2010 9:34 pm |
[ 4 posts ] |
