It is currently Tue Dec 23, 2025 11:19 pm
Reply to topic  [ 18 posts ]
 HELP!!! Home build
Post HELP!!! Home build
Could someone please help, i buit my own SD Looks great work for 5 min then belt started to slip! could one of yall please tell me what type of pulleys and belt or clutch these motors take. I have a 18h kolar rpms are about 3600, would love some help ive put in alot of time and effort into this build any help would be appraciated also were i could get this stuff would be great!
Thu Mar 01, 2012 6:38 pm
Post Re: HELP!!! Home build
what kind of belt
Thu Mar 01, 2012 6:49 pm
i put a 50 inch v belt on a 3.5 top pulley and a 4inch on the bottom i have no clue what type of set up these SD motors use, ive built this motor just buy looking at pics of MD and Gator tail.
Thu Mar 01, 2012 7:05 pm
Timing belt
Thu Mar 01, 2012 7:58 pm
Let's see some pix of this home build!
Thu Mar 01, 2012 8:01 pm
Chain and sprockets...alot cheaper than a timing belt setup and it won't slip!!
1846 GTB and 35 GTR
New GT Rig
Old Surface Drive Build
Thu Mar 01, 2012 8:02 pm
Thu Mar 01, 2012 8:11 pm
v-belts are not the best, slip too much for this application. Like the other guys said chain and sprockets or timing pulleys with 3/4 to 1 inch wide belts. I used martin H pitch timing pulleys for my build, the H is for heavy duty ba beeeeeeh. Think I had about 150 bucks tied up in them+ the tapered bushings to go in them for the right size bore. Don't give up these home builds will whip your butt if you let them. :mrgreen: :D
Thu Mar 01, 2012 8:52 pm
man thanks alot your right im about to pull out my hair! i got this thing done stuck it in the water it worked fine right off the bat then the more gas i gave it the slower it ran! i thought i was done with this thing!
Thu Mar 01, 2012 9:19 pm
Here are a few pics of the motor
Thu Mar 01, 2012 9:55 pm
idont have the finished pics yet but there coming
Thu Mar 01, 2012 10:30 pm
That brace is gnarly looking! I like the vintage coke machine also
Fri Mar 02, 2012 12:01 am
I'm using a outboard transom mount on my build as well and have been struggling trying to fab up a trim system. The ob mount has holes for statics trim positions but I wanted to be able to adjust it on the fly. Any ideas as far as the trim and very nice build.
1846 GTB and 35 GTR
New GT Rig
Fri Mar 02, 2012 7:21 am
coke machine was put on the back burner for now i need to finish it soon! as far as the trim goes, man mine only works when i lift it out of the water. that was the only thing i didnt think threw. mine would have worked better if i had lowerd it 3''. i tried to copy copper head MM theres seems to work good. if you had anymore questions be happy to answer them!
Fri Mar 02, 2012 5:17 pm
Man that is awesome that you were able to fab up that motor! Best of luck with it. Let us know how it turns out.
Fri Mar 02, 2012 8:56 pm
Man I hope no one accidentally trips and falls on that brace...could really hurt !!
Thu Mar 08, 2012 1:31 pm
Thu Mar 08, 2012 3:51 pm
I wish I had some helpful tips but I've never tried to build my own but it looks cooler then a polar bear's toe nail and I'm sure you'll get the bugs worked out soon....keep us posted, good luck!
1648 weld bilt being followed by a 35 gtr
Fri Mar 09, 2012 5:48 am
