It is currently Mon May 12, 2025 9:26 am
Reply to topic  [ 9 posts ]
 Need to make a drive shaft for a 9hp diesel long tail
Post Need to make a drive shaft for a 9hp diesel long tail
I have a drive shaft which I had made but it's not straight and I need to make another. It's for a 9hp diesel engine with a lot of torque for a 9hp. What should I make the drive shaft out of? I needs to be 1" or less in diameter.
Thanks!
Greg
Thu Mar 22, 2012 9:09 pm
Post Re: Need to make a drive shaft for a 9hp diesel long tail
Where are you getting your prop from?
The industry standard is a 3/4" 10 tpi threaded hub on a 3/4" shaft with a keyway in the u-joint end, that will hold up fine.
Thu Mar 22, 2012 9:28 pm
I have a Hopkins Propeller MB1 but I really need the MB11 I believe.
My motor runs a straight shaft, no u-joint.
And my prop goes on a smooth shaft with a shear pin.
But what is the shaft itself made of? That's what I need to know. I need to have one made here in Venezuela. You can see the motor at http://gregihnen.me
Thu Mar 22, 2012 9:32 pm
Go devil uses carbon steel
Thu Mar 22, 2012 11:14 pm
I typically use 3/4" 17-4 H1150 or 4140 Heat treated turned ground and polished. On a 9 hp you could probably get away with using cold rolled 1018.
Fri Mar 23, 2012 6:40 am
Fri Mar 23, 2012 7:26 am
i fished there in the past .... what a wonderful place... i would use 3/4" hot or cold roll steel... look at support races on metal buildings ... if memory service me they us that size too... good luck
Fri May 11, 2012 8:50 am
Wed May 16, 2012 7:36 am
every drive shaft on every mud motor made here in the states is a solid shaft, 3/4" for your application. 4140 stainless is common, cold roll steel will work and does for home builds on the cheap. with as many stumps/logs as you encounter, I would go with the solid shaft, not a tube. get the stainless if you can.
Fri May 18, 2012 4:10 am
Users browsing this forum: Google [Bot] and 123 guests
