It is currently Mon May 12, 2025 2:35 pm
Reply to topic  [ 3 posts ]
 Shaft housing
Post Shaft housing
Where do you get shaft housings? Or do you make them yourselfs? How do you make the housing so the bearings fit?
Mon Aug 20, 2012 10:43 pm
Post Re: Shaft housing
Made it 1 1/4 DOM tube three brass bushings 1 in OD 3/4 in ID may have to sand down the out side a little so the fit but not to much drill and tap your tube in the center and 2.5 in from the ends two holes per bushing I taped mine in 1/4 28 place your brass with a wood dowell seals came from carquest again 1 in OD 3/4 in ID your set screws for your bushings should be about 45 degrees apart drill and tap two extra holes for your grease nipples drill and t tap all holes before placing brass
You can't fix stupid but you can at least try and cut it off at the pass
Tue Aug 21, 2012 1:13 am
Do you have any pictures of it?
Wed Aug 22, 2012 9:01 pm
Users browsing this forum: No registered users and 145 guests
