55@28
Joined: Fri Apr 13, 2012 3:01 pm Posts: 238 Location: Eagle River, Alaska
 swamped go devil
So back home after swamping the boat, pulled the plugs and got the water out of the motor. Motor runs now. All water that will, has come out of drain hole. So my question is, what more do i need to do to avoid more problems?
| Tue Oct 16, 2012 10:19 pm |
take'emgator
Joined: Mon Oct 19, 2009 6:38 pm Posts: 10201 Location: SETX
 Re: swamped go devil
change oil at least 3 times to make sure all water is out. change filters every time, should be good to go, salt water or fresh water?
| Wed Oct 17, 2012 5:23 am |
Quack Stackin
Joined: Mon Feb 14, 2011 6:07 pm Posts: 759 Location: NE ALABAMA
Sell it and buy a gtr
| Wed Oct 17, 2012 5:32 am |
55@28
Fresh water. I was gonna drain the oil and replace oil, actually seems like good idea to do it a time or two, cheap insurance i guess. Mainly curious about all the water in the belt housing, i know its indestructable and all, just being cautious.
| Wed Oct 17, 2012 12:09 pm |
SmokeEater829
Joined: Sat Jun 13, 2009 8:48 pm Posts: 1830 Location: Belle Chasse, LA
Flush the belt housing with fresh water. Then liberally spray the inside of it with WD-40, Corrosion X, or something of that nature. Oil changes as stated before, and I'd change/regrease the shaft.
_________________ Mud Buddy 4500 Black Death hauling the Uncle J 18x58
| Wed Oct 17, 2012 12:15 pm |
Gigafowl
| Wed Oct 17, 2012 3:13 pm |
craig
Joined: Tue Jan 13, 2009 7:53 pm Posts: 7515 Location: Chauvin
_________________ 1750 GatorTail Extreme/Stage 3 37 GTR HD Procrastination is a lot like masturbation. Sure it sounds great at the time but, in the end your only f--k--g yourself.
| Wed Oct 17, 2012 4:00 pm |
CCC
Flush the motor with diesel, take the plug wires off and turn it over a couple times
| Wed Oct 17, 2012 5:17 pm |
JIMMY W
Joined: Tue Jan 13, 2009 8:02 pm Posts: 4534 Location: South Louisiana
Sell it!!
_________________ 17/54 GT EXTREME Center Console, Huntdeck w/ GTR 35
| Wed Oct 17, 2012 5:46 pm |
pooldoo73
Joined: Tue Jan 25, 2011 5:47 pm Posts: 886 Location: Plaquemine
If the toothed belt slips due to having a little oil on it, the belt will be trashed.
_________________ 18'x54"CC Hanko/ 36PD
| Fri Oct 19, 2012 9:27 am |
MaXXis85
People please do not put any kind of Fuel in the crank case of your motor. Fill it up with oil, let it warm up, then drain. Repeat until water is evacuated. Fuel is not meant to be in the crank case. it is a solvent.
| Fri Oct 19, 2012 10:21 am |
CCC
Diesel has enough oil in it, it won't hurt it Been doin it all my life
| Fri Oct 19, 2012 5:56 pm |
55@28
Didn't do diesel. 6 flushes and filters later, seems to be happy now. Didn't look pretty starting out.
| Fri Oct 19, 2012 6:04 pm |
270Handiman
Joined: Thu Dec 29, 2011 10:46 pm Posts: 2342 Location: Mandeville, LA
I think I would let it drain out the rest for the night, let all that milky oil settle, then in the morning leave the plug out and flush a quart or so through it to try to get the rest of that mily oil flushed out without cranking it up and Stirring it up again. Then when you get it to run clear, then cap it and fill it, then run and change again to see if it clears up.
| Fri Oct 19, 2012 6:41 pm |
vertical_edge_800
Joined: Thu Dec 30, 2010 5:48 am Posts: 274 Location: Palmer, Alaska
That swamping looks like the product of Rabbit Slough tide change.... I towed a guy out of there last week who sank his excel and black death 4500. When I pulled the plugs on his motor, it shot LOTS of water out of the cylinder. He did the same thing you did, lots of oil changes, drain carb. Be careful when you tie up the boat out there!
| Sun Oct 21, 2012 1:09 pm |
postalpaul
Joined: Sun Nov 01, 2009 6:25 pm Posts: 1935 Location: Kaufman- TEXAS
Swamped a long tail once called CoCo his words " hell son you just washed it out, drain the oil and change the filter after that run the hell out of it"
Changed oil twice been running great since, 4 years later
| Sun Oct 21, 2012 1:12 pm |
55@28
| Tue Oct 23, 2012 1:44 pm |
CootSlayerRMFT
Joined: Thu Feb 02, 2012 12:53 am Posts: 7565 Location: Prairieville, LA
Like Giga said, DEFINITELY pull the access plates off the lower and grease the two u-joints in there where that water is running out of. You can buy an aerosol "belt dressing" to spray on the belt, just to keep it in good shape. Screw buying grease from Go-Devil, it's nothing special. Go to a hardware store and buy marine grease in a tube and go to town. No sense in shipping the same damn thing from Baton Rouge to Alaska with a pretty label!
| Tue Oct 23, 2012 2:49 pm |
guysride
Sorry for pulling you through the trees!
| Fri Oct 26, 2012 8:45 pm |
