mnsherick
 Getting stuck
So I'm getting waaaay back into the shallows just fine with my new rig, but we have to push the boat to get out. Any tips/tricks to get some momentum and break free with a surface drive?
Thanks
Gator trax 18x62 hybrid Mud buddy HD 5500MAG BAMF
-Matt
Sent from my HTC EVO 3D using tapatalk
| Sun Nov 04, 2012 9:04 pm |
nasty
 Re: Getting stuck
Running hard bottom?
| Sun Nov 04, 2012 9:05 pm |
idacraw
 Re: Getting stuck
Use reverse.
| Sun Nov 04, 2012 9:06 pm |
duckduckboom
Joined: Tue Nov 23, 2010 6:33 pm Posts: 5603 Location: Corner of Hell an high water, La
 Re: Getting stuck
donuts
_________________ You have your whole life to be an idiot, take a day off!
| Sun Nov 04, 2012 9:07 pm |
mnsherick
 Re: Getting stuck
I'd say semi hard bottom...1-4 inches of silt then 4-8 inches of water in places.
-Matt
| Sun Nov 04, 2012 9:42 pm |
brianb
Joined: Mon Nov 29, 2010 6:02 pm Posts: 534 Location: louisiana
 Re: Getting stuck
if you hunt the same area over and over, spend some time blowing out a ditch with your prop in the same spot about the length of your boat. i have a gtr and do it by backing up and going forward, but with out reverse it will just take you a while longer to blow out a ditch then push it back and do it again, always take off in that same spot.
when you take off in the ditch, gap it wide open and let it get on step and then you are good to go.
_________________ gtr35 gt 1854 / w gatorglide 12 ft 11hp longtail 14 ft 10 hp longtail Merc 225hp TR20
| Sun Nov 04, 2012 9:50 pm |
Woodiebuster
 Re: Getting stuck
Unless you sink up to above your knees or better, the boat will struggle to take off in that. The prop has to be submerged completley in the mud/water and if it is thick or hard you will have alot of drag holding you back.
Go get stuck and sooner or later you will learn the limitation of your rig.
| Sun Nov 04, 2012 9:53 pm |
skinnerton_outlaw
Joined: Sat Oct 30, 2010 1:17 pm Posts: 578 Location: Monroeville, Alabama
 Re: Getting stuck
donuts or a figure 8, had to figure this one out on my own
_________________ Uncle J 17x54 GTR 35
| Sun Nov 04, 2012 10:38 pm |
Will
 Re: Getting stuck
If you don't have room for donuts but the boat is floating free hit the gas and when the water is gone let off, wait for the water to come back, it will push and lift the back of the boat slightly, full throttle when you feel the rise and push.
_________________ Before the internet, the majority of the village idiots stayed in their villages.
| Mon Nov 05, 2012 4:53 am |
Team Camo
Joined: Thu Oct 01, 2009 4:49 pm Posts: 8536 Location: Bridge City, TX
 Re: Getting stuck
That motor produces enough torque, you should trim down, gas it to about 3k-3500 rpm, & it should start to walk out. Then gradually trim up to keep momentum going & gain speed.
Just grabbing it & going wot is only gonna blow out the hole & leave you with nothing to bite on.
_________________ 1846 GTB & 35 GTR Team Gator-Tail
Killer Kallz & ANGLE PORT dealer (409) 720-8949
| Mon Nov 05, 2012 7:06 am |
CLICKSTER
 Re: Getting stuck
^^RIGHT^^
| Mon Nov 05, 2012 7:22 am |
Will
 Re: Getting stuck
That don't always work on a hard bottom, if it washes out, let off and let the water come back then gas it.
| Mon Nov 05, 2012 7:29 am |
mnsherick
 Re: Getting stuck
Some great info here guys thanks.
-Matt
| Mon Nov 05, 2012 7:42 am |
WestEndAngler
MMT Moderator
 Re: Getting stuck
| Mon Nov 05, 2012 7:46 am |
Will
 Re: Getting stuck
| Mon Nov 05, 2012 7:52 am |
petrel
Joined: Mon Jan 11, 2010 9:51 am Posts: 770 Location: NVA
 Re: Getting stuck
All great advice. One last thing: If you haven't already gotten a winch, get one!
_________________ Phowler 2066 w/ E5 37 ProDrive w/ Illowa Marine Heads MoMarsh Fatboy/2 Honda
| Mon Nov 05, 2012 8:48 am |
Boudreaux76
Joined: Tue Oct 30, 2012 7:21 pm Posts: 185 Location: Cypress, Texas
 Re: Getting stuck
When you are in the marsh.....what do you hook the cable to?
_________________ 1844 GD with 35HP GDSD
| Tue Nov 13, 2012 9:58 pm |
duckduckboom
 Re: Getting stuck
Anchor
| Tue Nov 13, 2012 10:04 pm |
petrel
 Re: Getting stuck
yep. The bigger the anchor, the less it buries itself too. It is a good idea to drill a hole in the the palm of the anchor and attach a line and float to it. That way you can pull the anchor out backwards if it is really stuck, or leave it marked and return to retrieve it when the tide comes in.
| Wed Nov 14, 2012 7:37 am |
deltaduckmaster
 Re: Getting stuck
I say take the BAMF in your signature and apply it!! If ghat don't work sell the motor and get you one with reverse!!
_________________ 17x48 extreme stage 2 GTR 20X60 DUAL RIG BOWFISHING ADDITION http://www.scalesandtailsbowfishing.com
| Wed Nov 14, 2012 7:41 am |
mnsherick
 Re: Getting stuck
| Wed Nov 14, 2012 10:46 am |
deltaduckmaster
 Re: Getting stuck
| Wed Nov 14, 2012 10:50 am |
deltaduckmaster
 Re: Getting stuck
I hunt the delta in south la. It's the end of the line were the united states drains I'm sure I know what hard bottom is!!
| Wed Nov 14, 2012 10:52 am |
take'emgator
Joined: Mon Oct 19, 2009 6:38 pm Posts: 10201 Location: SETX
 Re: Getting stuck
You ain't doing nothing with a silty hard bottom but eating a prop. Hard silty bottoms are the devil for these motors, you keep revving it up your only eating your prop. Just when you come in the flat in the mornings come in the same way everytime, you'll eventually eat yourself a ditch, If you can afford another prop get down on it and dig yourself a hole
| Wed Nov 14, 2012 10:57 am |
CJB
Joined: Tue Sep 13, 2011 11:46 am Posts: 5216 Location: Across the Bayou, LA
 Re: Getting stuck
_________________ 35 GTR - 1754 Extreme
| Wed Nov 14, 2012 11:21 am |
mnsherick
 Re: Getting stuck
| Wed Nov 14, 2012 12:58 pm |
deltaduckmaster
 Re: Getting stuck
| Wed Nov 14, 2012 1:04 pm |
