It is currently Thu Dec 25, 2025 7:37 am
[ 4 posts ] |
rob_E
Joined: Wed Jan 25, 2012 12:03 pm Posts: 1763 Location: Prairieville, LA
 11 inch props
When i bought my boat motor combo it came with 2 props a roughly 11 incher and one that is 11 and 7/8ths or so my boat runs a little faster and higher rpms with the smallerin deep water but much better un the mud and crud with the big blade. Also I had to have my prop shaft straightened out on the end from hitting a stump or something with the bigger prop that stuck down further than the skeg. My question is could i run an 11 inch prop with more pitch say 12 or 13 to acheive the same thing as a bigger prop with the standard 10 pitch?
_________________ 18X54 CC & 35 GTR w/ Hoyts Stage 1
| Wed Nov 14, 2012 8:45 am |
deltaduckmaster
 Re: 11 inch props
It will loose all bottom end
_________________ 17x48 extreme stage 2 GTR 20X60 DUAL RIG BOWFISHING ADDITION http://www.scalesandtailsbowfishing.com
| Wed Nov 14, 2012 9:51 am |
deltaduckmaster
 Re: 11 inch props
I take it you have a older model motor. Is it welded or is it a bolt up model. If bolt up you can get a new plate cut for it
| Wed Nov 14, 2012 9:53 am |
rob_E
 Re: 11 inch props
yea it is all welded straight and solid. I just need mods to push the big blade with my heavy ass boat just have to be careful with the prop i guess
| Wed Nov 14, 2012 2:17 pm |
[ 4 posts ] |
