It is currently Thu Dec 25, 2025 7:35 am
Reply to topic  [ 10 posts ]
 Teach me great Masters.....
Post Teach me great Masters.....
While my boat was in the shop today having some custom aluminum work done (pics tomorrow when the sun comes back up) the shop foreman told me I probably needed to replace my lower bearings and that the u-joint had to much play on the shaft. i asked him how he knew but then he suddenly had to handle a situation and I didn't have time to stick around. As he walked away he did point out a small metal ring no thicker than a key ring that was between the prop nuts and the lower bearing assembly.
So.....I turn to the other experts......
What do I look for?
1844 GD with 35HP GDSD
Tue Nov 13, 2012 8:05 pm
Post Re: Lower bearing
Anyone?..
Tue Nov 13, 2012 9:44 pm
This is what he showed me above the upper bearing where it's slipping. I think it just needs to be tightened? Thoughts?
Tue Nov 13, 2012 9:46 pm
Post Re: Teach me great Masters.....
Has to change the post title to get some attention. I have the afternoon off and was going to work on the boat to get ready for my first hunt in it on Saturday.
Wed Nov 14, 2012 6:17 am
Looks like it was tack welded to the key. I would replace the key also,looks worn.
Wed Nov 14, 2012 6:27 am
Look at your nut it has a grove in it. Your little washer has taken the shape of the nut. To much play.
Wed Nov 14, 2012 6:30 am
Wed Nov 14, 2012 8:47 am
At least someone tell me I can wait to fix it until the split......
Wed Nov 14, 2012 5:41 pm
Replace the bearing and key (machine shop or small engine shop might have one) also replace the washer. Check the threads when you take the nut off. It might last a year it might fall off tonight I haven't seen it.
Wed Nov 14, 2012 5:58 pm
