gtmorgan89
 Prop Questions. thinking my prop is way too big.
I bought a basket case Bog Hog mud motor. (not much to chose from up here in NE TN. I put it in the water and the boat will no plane out and feels like it has no power whatsoever. It will do less than 10mph. I spoke with backwater props, and they said I needed to know the gear ratios in order to determine prop size, and that they did not have a prop for this unit.
The Engine is a 24hp Honda gx670 and the prop os 12.5" from end to end, and is on a 1548 Xpress
Anyone have any idea what prop size I should run on this thing? And any leads on where one can be purchased?
| Thu Nov 01, 2012 8:10 pm |
autogateman
Joined: Thu Sep 16, 2010 10:32 pm Posts: 4036 Location: Gonzales La
 Re: Prop Questions. thinking my prop is way too big.
that looks like a pd prop to me
| Thu Nov 01, 2012 8:13 pm |
gtmorgan89
It very could be a PD prop. It was set up this way when I bought it. according to mudbuddy's sight I should be running a 9x6 or an 11x10. Is this correct? http://www.mudbuddy.com/Propeller%20Sel ... 0Guide.htm
| Thu Nov 01, 2012 8:38 pm |
autogateman
you really need to know your gear ratio before messing around with props, its an expensive trial and error
| Thu Nov 01, 2012 8:39 pm |
gtmorgan89
I'll Pull the cover first thing tom morning before work.
| Thu Nov 01, 2012 8:43 pm |
barnes_53
Could those pods hanging off of your stern also have anything to do with it? I have heard pods can be an inhibitor more than a benefit and could adversely affect performance.
| Thu Nov 01, 2012 9:07 pm |
gtmorgan89
Top is a 38 tooth and bottom is a 57.
As for the pods, I think they really helped the boat when I had a 25 merc. But you could be on to something with this motor
| Fri Nov 02, 2012 7:36 am |
mud slinger 69
Joined: Sun Aug 28, 2011 4:27 pm Posts: 1194 Location: Utah
Pods no good with surface drive.I think that prop is to big.Should be running a 11x10.Your gearing is is reduced alot. I'm running 23hp my gearing is 32 top 44 bottom.With 11x10 hill prop.On 15-48 G-3 it will run 22-23 mph
_________________ We ant just mormons and polyganists we got rednecks too
| Fri Nov 02, 2012 9:20 am |
Woodiebuster
Its a combination of prop and boat.
| Sat Nov 03, 2012 11:03 am |
CAJUN OUTLAW
You should be around 1.5:1 on ratio. I'd try a prop same size as a 23 gdsd. But the right prop won't fix the hull probs.
| Sat Nov 03, 2012 11:50 am |
gtmorgan89
Looking back I wish Id bit the bullet and bought a legit MM, and a dedicated mud hull.
I wanted to be able to swap out my 25 merc, and this mud motor for conditions, trips ect. and have a back up motor in case of doen time during waterfowl season.
Now, Should I be considering / modifying the pods to make my boat work with the mud motor?
I plan on calling bog hog in the morning to get the low down on my gear and prop setup.
| Sun Nov 04, 2012 8:23 pm |
gtmorgan89
I found this table on MudBuddys website. http://www.mudbuddy.com/opencart/index. ... ry&path=63Will the Tiger prop work on my lower unit? If so should I go for the 11x10 or the 12x11?
| Mon Nov 05, 2012 5:52 pm |
deadbird8
| Wed Nov 07, 2012 2:29 am |
gtmorgan89
According to my gear ratio, and mudbuddys prop chart, my prop should not be too far off, correct? I dont mind to buy a new prop but I want to make sure that will fix the problem. I gotta get this thing going before dcuk season!!!!!!
| Wed Nov 07, 2012 8:37 am |
MaXXis85
You have a 1.78:1 ratio. That means your motor is spinning 1.78 times for evert revolution of the prop. That is a good chunk of mechanical advantage.
| Wed Nov 07, 2012 9:27 am |
bbb
Joined: Wed Sep 02, 2009 2:54 pm Posts: 1554 Location: SW Georgia
You didn't say for sure, but I'm guessing your RPMs are low?
Plenty of folks around here with burned up props that you could try.
I have a MudBuddy Big Blade threaded. When I took it off my 35 GDSD, my boat was only running 21mph with 2 people and gear, but pushing the Rev limiter at 4300. With a new prop it runs 27 at 4100rpms, so there is a little life left to it.
If you pay for the shipping, I'll send it to you. USPS Priority Mail should be around $10.
Edit: Let me make sure it wasn't thrown away with my last Storage Shed purge.
_________________ 19x54 Seminole Extreme with a 35hp CDI GDSD. Mikuni. Marsh Mellow. Heads. Cam.
| Wed Nov 07, 2012 11:03 am |
gtmorgan89
just ordered one of these to see what RPM's im getting to the prop http://www.ebay.com/itm/Handheld-Digita ... 337d0fd5cdhopefully this will give me some more insight. I really appreciate all the help guys.
| Wed Nov 07, 2012 12:13 pm |
Mag10
Joined: Wed Jan 14, 2009 12:31 pm Posts: 342 Location: Faribault, Mn
Just watch out on the prop thread. I know bog hog uses a fine thread on their longtails vs. the industry standard 3/4-10. They may be doing the same on the surface drive...
| Wed Nov 07, 2012 4:56 pm |
gtmorgan89
Just got the laser tach in the mail today and tried it out on the prop. Its showing around 2700 rpms at WOT. Right after I got his figure I got the guys at Bog Hog to get me a figure on the gears. The stock bottom gear is supposed to have 47 teeth, mine has 57.
A smaller gear should give me more RPM's.
Is this pulley my answer to my problems?
| Tue Nov 13, 2012 9:37 pm |
odass
What rpms Is your motor running
_________________ Dead Fowl Custom 1954hd with a GTR
| Sun Nov 18, 2012 3:34 pm |
