goodblasson
Joined: Fri Apr 30, 2010 11:26 am Posts: 254 Location: Lafayette, La
 Any photos of Go Devil prop removal tool?
I am having hell getting this prop off of 23GDSD. Anyone have photos of the prop removal tool or a home made one? I have tried using a 2x4 for leverage like giga suggest, big hammer and block of wood, heat.. it aint budging, infact I may have ruined my cav plate trying to gain some leverage. I can get a fab shop to make prop tool for me but I was hoping to get a picture to figure out what I am trying to build.
I always told myself this GD would suffice for what I do, didnt need power trim because I mainly run tight timber and always need to lift motor in and out of water to get over logs, didnt need neutral either in timber, why reverse when I had a push pole, but damn this aint no fun removing a GD prop, this might be the deal breaker, whats so complicated about using a hex???
| Tue Nov 20, 2012 8:20 am |
craig
Joined: Tue Jan 13, 2009 7:53 pm Posts: 7515 Location: Chauvin
 Re: Any photos of Go Devil prop removal tool?
_________________ 1750 GatorTail Extreme/Stage 3 37 GTR HD Procrastination is a lot like masturbation. Sure it sounds great at the time but, in the end your only f--k--g yourself.
| Tue Nov 20, 2012 8:30 am |
CootSlayerRMFT
Joined: Thu Feb 02, 2012 12:53 am Posts: 7565 Location: Prairieville, LA
 **Sent from my Obama Phone**
| Tue Nov 20, 2012 8:32 am |
goodblasson
Damn!!! LOL
| Tue Nov 20, 2012 8:34 am |
lastchance
Joined: Wed Feb 09, 2011 1:56 pm Posts: 1646 Location: Chauvin
| Tue Nov 20, 2012 8:46 am |
STR8limits
Joined: Sun Sep 16, 2012 7:20 pm Posts: 133 Location: Tx
Mine was really easy. Put a crescent on the top nut against ur cavation plate and put a big crowbar between the blades on prop. Twist it right off. U may have to use a cheater pipe on it if it's been a while since removed. I put no seize back on the threads
_________________ 35 GDSD STAGE 2-18x44 GUTTED GD
| Tue Nov 20, 2012 9:32 am |
THEWOOD
Joined: Thu May 03, 2012 1:30 pm Posts: 333 Location: Marrero/Lafitte LA
| Tue Nov 20, 2012 9:14 pm |
sdm111
I used a crescent wrench on the front nut and a weight lifting bar between the prop and shaft.
| Wed Nov 21, 2012 4:58 am |
Buzz Killington
have you hit it with penetrating grease?
Leverage is key - big wrench with an extension - 2x4 works sometimes/most time - but when you do get it off - Anti-Seize the thing. Then removal will be easier...
B. MacDonald
| Wed Nov 21, 2012 7:39 am |
da go get'er
Joined: Wed Oct 27, 2010 8:30 am Posts: 3406 Location: Prairieville
don't have a picture but it does make life much easier having one. I'd suggest getting one if you plan on keeping the motor for a good while.
_________________ 17*38 Klibert 23GDLT I toast to staying positive and testing negative!
| Wed Nov 21, 2012 8:44 am |
goodblasson
I will post pics later today of what I built, prop came off no problem once I had the right tools for the job. A prop removal tool is a must for this motor. If anyone in Lafayette ever needs to borrow it let me know, it will work for surface drive or longtail.
| Wed Nov 21, 2012 9:07 am |
Gigafowl
| Sun Nov 25, 2012 4:13 pm |
