It is currently Thu Dec 25, 2025 7:36 am
Reply to topic  [ 6 posts ]
 problem getting MB clutch and crank cover off
Post problem getting MB clutch and crank cover off
I blew a crankcase seal on my 35hp MB. I have most of the drive off but cant get the top gear off. Its got some kind of clutch plate on it after i removed the clutch. It seems to be attached to the top gear. Anyone have any info on this. Does the top gear get pulled outwards away from the motor? Thanks
Sun Nov 25, 2012 11:58 am
Post Re: problem getting MB clutch and crank cover off
The piece that stayed on the top gear is round with slits through it its really flimsey.
Sun Nov 25, 2012 12:02 pm
that is the other half of the clutch. pry it off as an assy but pry behind the gear not the plate. you bend those tabs and you cost yourself 200 for a new clutch
Sun Nov 25, 2012 1:47 pm
Spray the shaft good with wd-40 or other oil & let it sit for a while. Use a block of wood and hammer or mallet to break it free. Probably just seized up from being on too long
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sun Nov 25, 2012 1:53 pm
Spray some PB Blaster on the crank and let it sit then it will let go
1754 With Level 3 GTR
Sun Nov 25, 2012 6:16 pm
Thanks guys got it off
Sun Nov 25, 2012 7:27 pm
