Ole Boudreaux
 Trim on a mudbuddy 45 mag
I get done hunting yesterday. Load up the boat trim the motor up. As I'm strapping down the boat the trim comes on and won't stop. I had to disconnect the battery to stop. Any ideas? Thanks happy holiday
Fri Dec 25, 2015 1:46 pm |
flint87
 Re: Trim on a mudbuddy 45 mag
Gotta be in your trim switch
Fri Dec 25, 2015 1:47 pm |
Ole Boudreaux
Can I get that part at napa? Or is it a mud buddy part only?
Fri Dec 25, 2015 1:55 pm |
JD145
Joined: Wed Jun 04, 2014 9:01 pm Posts: 1289 Location: SWGA
You may be able to find one Somewhere else not sure, just call boatDR, he can fix you up.
_________________ 1854 Prodigy DPE Level 3 HDR
Fri Dec 25, 2015 2:01 pm |
lunacris
Joined: Thu Mar 29, 2012 8:31 pm Posts: 3251 Location: Da Parish
get the new style trim switch. i just upgraded mine, its wonderful.
_________________ GatorHide - MB
Fri Dec 25, 2015 2:02 pm |
Gunshinestate407
Joined: Tue Dec 23, 2014 1:58 pm Posts: 216 Location: Orlando
Call boat dr. He had 2 new ones on my door step in a couple days.
Fri Dec 25, 2015 2:29 pm |
flint87
Disregard my last post. I just went full fucking retard talking about a clutch switch. This is why I drive a godevil... That and I'm too poor for a fancy mud buddy.
Fri Dec 25, 2015 4:48 pm |
deadbird8
Sun Dec 27, 2015 3:05 pm |
DmaxHunter
Joined: Wed Jan 18, 2012 7:21 pm Posts: 2207 Location: North Alabama
_________________ 2014 PRODIGY 1754 (#19) 2014 5500 BAMF HDR RETRO SOLD
Sun Dec 27, 2015 4:10 pm |
Ole Boudreaux
Ok I changed trim switch,both relays, and both fuses. Still doesn't work. I think it's the motor. Can I buy a motor of eBay for 130$ or do I need to replace everything which would cost about 700$. Thanks for the help.
Thu Jan 07, 2016 6:30 pm |
DmaxHunter
A couple have bought just the motor from Amazon or eBay, they posted the part number. Maybe someone will chime in
Thu Jan 07, 2016 6:54 pm |
DENNYEDWARDS
Joined: Sun Aug 09, 2009 12:50 pm Posts: 574 Location: Muscatine, Iowa
Amazon .com Mercury replacement trim motor. It is a direct replacement #809885A $122. Magnets came unglued in Motors case and locked it up in mine. Save your drive pin that goes in to pump, otherwise you may have to shorten the one that comes with motor. Will have to add fluid to resivour, because you will loose some when removing it from pump housing. They are self bleeding so you may hook it up to a battery, and run the cylinder up and down a few times to get air out of it. We clamp them up in vise and do this. Reverse pump wires to battery to reverse motor for up and down. Check res. level before installing back on motor. Saves much $$ over one from MB.
Sun Jan 17, 2016 10:13 am |
lunacris
Sun Jan 17, 2016 11:44 am |
lunacris
Sun Jan 17, 2016 11:52 am |
Migrator
Joined: Sun Apr 17, 2011 2:29 pm Posts: 3227 Location: Black River, MS
Chris, is this the new mercury trim switch that comes on the HDR's? If so I like that switch. Should hold up much better than the old ones.
_________________ WC CUSTOM 20X54 Battleship w/ Gator Glide Pushed & Pulled hard by an HDR!
Don't be scared...Hit It and Hold It!!!
Sun Jan 17, 2016 2:34 pm |
lunacris
it is.... i love how its recessed into the handle. the new clutch switch is also a big upgrade.
Sun Jan 17, 2016 2:52 pm |
DmaxHunter
Luna are the parts online, or did you call and order
Sun Jan 17, 2016 10:08 pm |
lunacris
Andy hooked me up
Mon Jan 18, 2016 8:18 am |
