It is currently Fri Dec 26, 2025 4:19 pm
Reply to topic  [ 4 posts ]
 MB HD 4000 Grease inside air cooled out drive ftgs
Post MB HD 4000 Grease inside air cooled out drive ftgs
I'm replacing the air cooling tube as it's kind of worn out between the engine cooling shroud and the outdrive which appears to cooling the clutch while in operation, I noticed when I took it apart that it there seem to be greased smeared on the inside of the barbed hose fittings I'm guessing this is to act as a bit of a filter to try and pick up any dust or dirt... can anybody confirm this? Thanks fellas.
Sent from my XT1585 using Tapatalk
Tue Oct 18, 2016 8:00 am
Post Re: MB HD 4000 Grease inside air cooled out drive ftgs
Just guessing here but it could possibly be from the belt slinging grease from over greasing the bearings or smearing grease on the hose to install?
Tue Oct 18, 2016 10:13 pm
Wed Oct 19, 2016 4:21 pm
I'd pop off the clutch cover and have a look your seal behind the gear on drive my be shot and is leaking grease into the belt box.
1754 With Level 3 GTR
Thu Oct 20, 2016 7:50 am
