It is currently Thu May 24, 2018 1:38 pm
Reply to topic  [ 24 posts ]
 Prodrive Clutch
Post Prodrive Clutch
When just drifting around clutch holds but put a load it feels like it slips and won't hold the power. Anyone experience this? If the clutch I saw an aftermarket some where?
Sent from my SM-G928V using Tapatalk
Sat Jun 17, 2017 9:58 am
Online
Post Re: Prodrive Clutch
What do you mean the clutch wont hold power?
As in electrical power?
dead animal wrote:
Giga, u need a fukin throat punch. if u want flotation, good for u, but don't ever, for 1 second of your miserable life, think u can tell me what to do.
whatever
Sat Jun 17, 2017 5:07 pm
No as in when the throttle is nailed it slips.
Sat Jun 17, 2017 6:08 pm
Online
Do you have high rpm's just not going anywhere?
Give us more info on what its doing to make you think its slipping
whatever
Sat Jun 17, 2017 6:21 pm
When going to get up on step and giving it more throttle it starts high trying without going anywhere.
Sat Jun 17, 2017 7:00 pm
Online
What does your prop look like? Whats it measure?
New? Old?
Sounds like a burnt prop
whatever
Sat Jun 17, 2017 7:03 pm
Thought that myself. Took a prop off my buddies boat that was ran and did the same thing.
Sat Jun 17, 2017 7:05 pm
Online
Hmm.
Have you greased the lower unit lately?
I ask because you could have over greased it and there is grease on the clutch.
Sounds like you may be pulling the powerhead to inspect it. Might have a loose clutch bolt
whatever
Sat Jun 17, 2017 7:10 pm
Yea I'm going to pull the powerhead and inspect the clutch. What's the best option for a replacement?
Sat Jun 17, 2017 7:14 pm
Online
I saw there is a clutch on amazon I believe.
I think that's the one banded-mallard bought. Its got a bearing upgrade or something.
Or you can order one from prodrive.
Here it is.
https://www.amazon.com/Replaces-5218-26 ... ive+clutch
whatever
Sat Jun 17, 2017 7:19 pm
Online
Blueshamu has a thread somewhere on here. He's running something different, too.
Sent from my SAMSUNG-SM-G891A using Tapatalk
Sat Jun 17, 2017 7:27 pm
Xtreme Outdoor Power....they have a replacement for the PD clutch.
18' x 54" Uncle J Custom Center Console w/36 HP Prodrive - The FULL Story!
Backwater Performance Systems
Swamp Staff
WhoDat88 wrote:
Just think how much better MMT would be with out Dean as a member.
Sun Jun 18, 2017 8:01 pm
Online
Yeap, that's the link I posted. Comes from Xtreme
whatever
Sun Jun 18, 2017 8:17 pm
Online
Here it is.
Yep that's it. A lot cheaper and direct bolt up.
?? HP Kawasaki Powered PD pushing a 1748 beyond the laws of physics
Mon Jun 19, 2017 4:20 am
Appreciate it guys. Got it ordered.
Mon Jun 19, 2017 5:03 am
Call Xtreme direct...make sure you are getting the right clutch. They may want you to measure the crank length.
Swamp Staff
Mon Jun 19, 2017 5:21 am
Ok it's for a Gen 4 w/ 37EFI.
Mon Jun 19, 2017 6:49 am
Online
Hmmm. That may be the wrong one then. I know they started with a heavy duty clutch. Don't know if that matters or not.
whatever
Mon Jun 19, 2017 7:00 am
I've ran one of their clutches for the past year, somewhere in the ball park of 70+ hours with no problems.
Mon Jun 19, 2017 6:45 pm
Little update. I cancelled the order with extreme powersports. I talked to their guy and he was not sure if he had what I needed so I gave Nick Peltier a call and ordered the one from prodrive. I did fine out it is the new heavy duty one. I'm ready to get this thing back on the lake. By the way any parts call Nick he is jam up.
Tue Jun 20, 2017 5:05 am
New clutch installed and all problems are gone. New clutch was very easy.
Mon Jun 26, 2017 7:21 am
Online
Awesome!
Glad you got it all done correctly
whatever
Mon Jun 26, 2017 7:30 am
Online
Do you mind giving a quick run down of the steps involved in changing it? I've never heard anyone call it "very easy" before, but I've never done it.
BROOKS wrote:
A life long feller I knew is now dead 'cause of homemade liquor !!!! His brother has the mental retard 'cause of it !!!!
1660 Gatortail & 36 PD
Mon Jul 03, 2017 4:14 pm
Yea not a problem.
Remove the 4 main bolts holding the frame to the motor plate.
I use a chain fall in my shop to lift the motor directly up. Using the chain fall I put pressure on it and give it a shake and then pressure until it lets go.
Once it breaks free you remove the 4 bolts holding the spline adapter on and remove the clutch by applying pressure.
The new clutch came with new clutch holding bolts which had to be out in.
Slide the new clutch on and lower her back down slowly making sure she seats correctly.
Tighten everything back down and test run.
I can get more in detail if you need.
Mon Jul 03, 2017 8:03 pm
Users browsing this forum: No registered users and 23 guests
