It is currently Mon Dec 15, 2025 8:43 am
[ 7 posts ] |
fowl habbit
Joined: Sat Jan 16, 2010 1:52 pm Posts: 1130 Location: THE ONE AND ONLY BUFFALO COUNTY
 3 BLADE RPM???
I just put the new 3 blade on my mud motor this afternoon and It gets me outta the hole fast and seems fast on plane. My concern is when I was running the Big 2 Blade tiger prop I was getiing like 4450 to 4500 now with 3 blade I went to like 3900 rpms it seems like its opening up but it also pushes against me really bad. Wondering if this is common or if I need to adjust somthing. I knew I would loose some Rpms but didnt think it would that many. Any help is greatly appreciated
| Tue Sep 14, 2010 7:03 pm |
b_coonass
Joined: Thu Mar 26, 2009 2:08 pm Posts: 1229 Location: morgan city, louisiana
 Re: 3 BLADE RPM???
_________________ 36hp Pro-Drive with EVT exhaust pushin a 17x42 custom skiff
| Tue Sep 14, 2010 7:06 pm |
fowl habbit
 Re: 3 BLADE RPM???
To eliminate the Pushing of the motor can I move the motor on transom and do I move it towards me or away
| Tue Sep 14, 2010 7:08 pm |
rebbeer
Joined: Thu Feb 05, 2009 7:39 pm Posts: 417 Location: Lafayette, LA
 Re: 3 BLADE RPM???
You should move it away from you. If it's pushing that bad, it may not make that big of a diference. You'd just have to try it and see.
_________________ 35 hp CDI MB HD Sport pushing a 17'6" Uncle J custom bateau
| Thu Sep 16, 2010 2:26 pm |
fowl habbit
 Re: 3 BLADE RPM???
I moved it away didin tmake that big off differnce. I bent the skek a little that didrection it helped some Ill just have to fight it a little.
| Fri Sep 17, 2010 8:33 am |
b_coonass
 Re: 3 BLADE RPM???
Try moving around the weight in you boat!
| Mon Sep 20, 2010 1:59 pm |
fowl habbit
 Re: 3 BLADE RPM???
Bent the skeg away from me That seemed to help. I also notice If I put more weight on the opposite side of me it doesnt push as bad.Either way the 3 blade throws me outta the hole lost a little top end but it carrys a load way better. Thanks again
| Tue Sep 21, 2010 5:41 pm |
[ 7 posts ] |
