3 BLADE RPM???
http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=12376
Author:  fowl habbit [ Tue Sep 14, 2010 7:03 pm ]
Post subject:  3 BLADE RPM???
I just put the new 3 blade on my mud motor this afternoon and It gets me outta the hole fast and seems fast on plane. My concern is when I was running the Big 2 Blade tiger prop I was getiing like 4450 to 4500 now with 3 blade I went to like 3900 rpms it seems like its opening up but it also pushes against me really bad. Wondering if this is common or if I need to adjust somthing. I knew I would loose some Rpms but didnt think it would that many. Any help is greatly appreciated
Author:  b_coonass [ Tue Sep 14, 2010 7:06 pm ]
Post subject:  Re: 3 BLADE RPM???
Author:  fowl habbit [ Tue Sep 14, 2010 7:08 pm ]
To eliminate the Pushing of the motor can I move the motor on transom and do I move it towards me or away
Author:  rebbeer [ Thu Sep 16, 2010 2:26 pm ]
You should move it away from you. If it's pushing that bad, it may not make that big of a diference. You'd just have to try it and see.
Author:  fowl habbit [ Fri Sep 17, 2010 8:33 am ]
I moved it away didin tmake that big off differnce. I bent the skek a little that didrection it helped some Ill just have to fight it a little.
Author:  b_coonass [ Mon Sep 20, 2010 1:59 pm ]
Try moving around the weight in you boat!
Author:  fowl habbit [ Tue Sep 21, 2010 5:41 pm ]
Bent the skeg away from me That seemed to help. I also notice If I put more weight on the opposite side of me it doesnt push as bad.Either way the 3 blade throws me outta the hole lost a little top end but it carrys a load way better. Thanks again
