It is currently Fri Dec 19, 2025 2:57 pm
Reply to topic  [ 17 posts ]
 PD 36 Lower Unit - Should prop turn freely?
Post PD 36 Lower Unit - Should prop turn freely?
Just never noticed. I am getting ready to change my seals. And, I noticed that the prop has a good bit of resistance when I hand turn it (motor off/clutch disengaged). It's not real hard but it does not spin freely like my 150 Evinrude. Should it? :?
Tue Sep 14, 2010 5:30 pm
Post Re: PD 36 Lower Unit - Should prop turn freely?
nope
Tue Sep 14, 2010 5:43 pm
Sounds normal to me, its not gonna spin anything like an outboard.
Tue Sep 14, 2010 7:53 pm
OK Thanks. Just checking
Wed Sep 15, 2010 5:59 pm
"You may all go to hell, as for me I'm going to Texas" D. Crockett
What is best in life?
To crush your enemies, to see them driven before you, and to hear the lamentations of their women.
Thu Sep 16, 2010 3:23 pm
I think the gears in the lower unit probably cause the resistance even when the motor is declutched. So, I still have a little concern because I obviously had a lot of water in my lower unit and I worry that some damage was done.
Fri Sep 17, 2010 4:37 pm
Fri Sep 17, 2010 8:53 pm
I have the seal kit and have the prop nut off. Trying to find a prop wrench to remove the prop. Anybody know where to get one?
Sun Sep 19, 2010 9:08 am
I've been using a crowbar and it works great...
Sun Sep 19, 2010 10:50 am
Really? I put a crowbar on it and I was afraid to go to hard on top of the shaft. I was afraid of slightly bending the shaft. I guess that wasn't a problem for you! Maybe I'll man up and try it again with a crowbar. :lol:
Sun Sep 19, 2010 12:40 pm
May not be a good idea, I dunno. Its worked though, several times. :lol: The one they use on these props is different that what I've seen for a regular outboard. Looks more like a piece of flat bar. Only thing I would say you need to be careful with when using a crowbar is messing up the threads. Usually I can get it to break free pretty easy with a crow bar, and then just turn it by hand. Make sure you use anti-seize when putting it back on
There's a pic of their prop wrench on pg 18-19
http://prodriveoutboards.com/images/Pro ... nual08.pdf
Sun Sep 19, 2010 1:00 pm
Get a piece of flat bar and drill a hole in it big enough for the shaft. Viola, prop wrench.
Sun Sep 19, 2010 1:36 pm
Get a 6ft 2x4,drill a hole in one end big enough to fit over the prop shaft and slip it on the shaft and slide it up between the blades of the prop.Drop a 1/2 inch bolt in the hole by the clutch(look at the owners manual for location) and bear down on the 2x4 till the prop spins loose-it will be pretty tight at first since its pulled up on a tapered shaft with a bushing.Using the 2x4 will keep your threads from getting buggered up,just wire brush the threads before you make it back up.
Mon Sep 20, 2010 4:47 am
Great idea. Man, I love this website. :D
Mon Sep 20, 2010 5:42 am
Don't forget to apply marine grade never-seez to the shaft and what not before you put the prop back on. http://www.neverseezproducts.com/marine.htm
Mon Sep 20, 2010 6:52 am
The 2 x 4 worked great. Prop came right off. Draining the old oil out now. Looks really milky. The good thing is that there doesn't seem to be any metal particles in the oil. I don't think I will have any other problem. Hopefully the new seal will keep the water out. I have some marine grade grease - will that work in place of the Never Seez? No stores around me had Never Seez. If grease doesn't work then I'll probably be able to get some this weekend.
Tue Sep 21, 2010 8:15 pm
wait and get the never seez
1748 pd boat w/ 36pd hht & fpr
Wed Oct 13, 2010 9:26 am
