Re: scavenger backwater mud motor prop info.
that is what they use. only thing i can figure on the motor turned backwards is it was the easiest way to mount it. i didnt know you could get the auger in both hands. that was the other reason i guessed the motor was turned around. if so you could build an auger prop for any long tail? i have run the scavenger. the props are not very efficient but they handle rocks very well. this would be a good option for someone running rock rivers.
