| pro-drive power trim http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=13383 |
| Author: | n.o.yat [ Wed Oct 27, 2010 4:21 pm ] |
| Post subject: | pro-drive power trim |
my powertrim om pd is very slow and making a growling sound. it makes it going up and down. after a few times it seems the motor gets hot and quits working. after it cools down it will work again w/ the same growling sound. if it is my motor any idea what one would cost? it looks like i may have to remove the motor off the boat to replace it. |
| Author: | cb5331 [ Wed Oct 27, 2010 4:24 pm ] |
| Post subject: | Re: pro-drive power trim |
Bad connections can create a lot of extra heat. Check all of em, both ends... |
| Author: | OwenDickeson [ Wed Oct 27, 2010 5:08 pm ] |
How old is your power trim? The older ones had problems with moisture getting in the motor and corroding everything. Same symptoms as your describing. |
| Author: | JIMMY W [ Wed Oct 27, 2010 5:54 pm ] |
It sure will do the same thing when it gets wet!! |
| Author: | n.o.yat [ Thu Oct 28, 2010 7:07 am ] |
the motor is about two years old. i sent kp at pd a video, hopefully he will get back w/ me today. |
| Author: | n.o.yat [ Thu Oct 28, 2010 4:38 pm ] |
tell ya what owen, man you know your stuff. i took the motor apart and it definetly has moisture issues going on. when i talked to kp earlier he did say that they no longer use that unit. my motor is two years old, i have to see, hopefully is still under warrrenty. |
| Author: | OwenDickeson [ Thu Oct 28, 2010 4:45 pm ] |
I doubt it will still be under warranty because the frame is only a 1 year warranty. Call KP though and he will order you a new setup for what it costs them to get it. |
| Author: | n.o.yat [ Thu Oct 28, 2010 4:48 pm ] |
yeah he said 150.00 i can live with that. |
| Author: | OwenDickeson [ Thu Oct 28, 2010 4:53 pm ] |
Yeah I was gonna say that it should be between 100-200$ lol. |
| Author: | n.o.yat [ Sun Oct 31, 2010 5:35 pm ] |
gonna ordre one monday morn so it will be here. went to the lease in my flatboat and way to much work w/ low water conditions. good luck on your season owen. |
| Author: | smokingun [ Mon Nov 01, 2010 12:11 pm ] |
Before you order the motor, I would check your trim switch because mine had moisture problems. Just thought i would give you the heads up to a problem that might happen later and maybe save you some on shipping. |
