It is currently Sat May 10, 2025 6:21 am
[ 5 posts ] |
go-devil15
Joined: Thu Oct 28, 2010 7:30 pm Posts: 115 Location: Abbeville,LA
 go-devil shaft smoking?
i have the older style go-devil were it is a brass sleeve and rubber seal at the top of the frame by the u-joint, after i run it for about 20-30 mins, smoke starts to come frome inside the frame were my shaft goes. is this a big problem, i have enough grease in there, so is this the grease just getting really hot or what?
_________________ Running a homemade 14x38 skiff with the good ole' 13 h.p Go-Devil longtail
Fri Oct 29, 2010 10:29 pm |
stualaska
Joined: Sat Jan 17, 2009 1:34 am Posts: 578 Location: North Pole, Alaska
 Re: go-devil shaft smoking?
If it is getting hot enough to smoke it's a problem. It will probably cook your seals. Sounds like the shaft isn't centered in the upper bushing. Has the engine or universal been moved recently? Have you hit something hard enough to bend the outer tube?
_________________ so many rivers, so little time
Sat Oct 30, 2010 12:14 am |
go-devil15
it isnt alot of smoke, also its a brand new shaft and sleeve and seals. when i brought it over to my local go-devil dealership, they told me that its just the grease inside their that is getting extremly hot, should i try a different type of grease? if so which kind?
Sat Oct 30, 2010 8:09 am |
stualaska
The new info helps. Sounds like the clearance between bushing and shaft is tight and that's not necessarily bad. Normal wear will center the shaft in the bushing and it should stop getting hot over time. As long as the paint on the outer tube doesn't blister you should be good to go. Use whatever grease the dealer recommends. I've been using Chevron #2 red chassis and wheel bearing grease for over 20 years with good results. If the heat cooks the seals you will know it by a puddle of grease forming under the upper seal collar.
Sat Oct 30, 2010 3:24 pm |
go-devil15
yep you are right, i remeber it was a kinda tight fit for the shaft in that sleeve. but i defintely doesnt get hot enough for the paint to start blistering, thanks for the info
Sat Oct 30, 2010 8:50 pm |
[ 5 posts ] |
Users browsing this forum: No registered users and 129 guests |
