How to change prop on Pro Drive??
http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=17565
Author:  duramaxdiesel09 [ Thu Apr 07, 2011 6:54 pm ]
Post subject:  How to change prop on Pro Drive??
I got my new prop today and can't seem to get the old one off. It almost seems like it is seized up on the shaft. Some pointers or directions on how to do it properly would be great. Thank, Chase.
Author:  OwenDickeson [ Thu Apr 07, 2011 6:55 pm ]
Post subject:  Re: How to change prop on Pro Drive??
What all are you using and what have you done so far?
Author:  duramaxdiesel09 [ Thu Apr 07, 2011 6:57 pm ]
took the nut off and tried to hit the end of the prop with a dead blow hammer to get it loose.
Author:  OwenDickeson [ Thu Apr 07, 2011 6:58 pm ]
Well that was retarded.
Do you not have the manual that came with your motor?
Author:  meterman3 [ Thu Apr 07, 2011 6:59 pm ]
go to thier web site down load pf file you take nut off did u put the 1/2 bolt in the hole to freeze the shaft
Author:  duramaxdiesel09 [ Thu Apr 07, 2011 7:00 pm ]
No. I do not. It seemed logical to me. I didn't do it but 2 or 3 times and it occurred to me that wasn't right. It would be great if I could get some pointers.
Author:  meterman3 [ Thu Apr 07, 2011 7:00 pm ]
owen what is a wiggles ?
Author:  OwenDickeson [ Thu Apr 07, 2011 7:02 pm ]
Did you do anything to keep the shaft from spinning?
Author:  duramaxdiesel09 [ Thu Apr 07, 2011 7:03 pm ]
Got it now. Thanks meterman.
Author:  OwenDickeson [ Thu Apr 07, 2011 7:04 pm ]
http://www.prodriveoutboards.com/images ... nual08.pdf
Author:  OwenDickeson [ Thu Apr 07, 2011 7:05 pm ]
Author:  POKER1 [ Thu Apr 07, 2011 10:08 pm ]
Buy the prop wrench and machined pin to lock the shaft up from PD. Its a great investment and will make your life much easier.
Author:  bayouboy [ Thu Apr 07, 2011 10:38 pm ]
X2
a couple little tips when your removing the prop trim the motor down a little then look at the front the prop ( toward the bow) turn the prop until the slot in the prop bushing is on top the shaft, either pour a little 90w or shoot some WD-40 in the slot this will lube the bushing as it turns on the prop shaft.
When your reinstalling the prop and after you coat the threads with never sieze run a line of 90W oil across the top the threads, it will come off twice as easy the next time round.
Author:  duramaxdiesel09 [ Thu Apr 07, 2011 10:42 pm ]
Alright guys thanks. My pop is a machinist so he can make the tools so I won't have to spend that money.
Author:  bayouboy [ Thu Apr 07, 2011 10:52 pm ]
Author:  duramaxdiesel09 [ Thu Apr 07, 2011 10:57 pm ]
Author:  BradS [ Mon Apr 11, 2011 2:53 pm ]
Ask him to learn ya
Author:  duramaxdiesel09 [ Mon Apr 11, 2011 8:27 pm ]
Oh I'm watchin and learnin all I can!!
