It is currently Sun May 11, 2025 10:07 pm
Reply to topic  [ 12 posts ]
 Trim crap, and Lost plug/allen head screw on lower unit
Post Trim crap, and Lost plug/allen head screw on lower unit
I bought a brand new PRO Drive rig from them and already having problems. I have a mere 4.5 hours and i already have 2 things wrong. The little allen head plug that goes on the side the shaft to grease it fell out, and the hydraulic trim is already gone to S#!T.......It trims down fine, but coming back up sometimes doesn't work so well!......its like it binds up sometimes, almost like there is some kind of trash or shavings in the aluminum block where the hydro fluid runs. Any help or insight would be appreciated on what to do about this!
Sat Nov 26, 2011 10:04 pm
Post Re: Trim crap, and Lost plug/allen head screw on lower unit
Have you contacted ProDrive yet??
Sat Nov 26, 2011 10:07 pm
sent them an email......that was fri, but do you think that they would send me a new plug or would i have to pay....i know it cant be expensive at all but just wondering.
Sat Nov 26, 2011 10:16 pm
18x48 Charles Leonard / 36PD
Sat Nov 26, 2011 10:40 pm
check your battery connections to make sure they tight
I gave up mud motors
Sat Nov 26, 2011 10:46 pm
the hdryo trim on my did that about the same amount of hrs. the switch had went bad. reverse the wires on your trim switch to see if it will work, if so that is the problem. called kp and had a new 2 days later, under warranty.
pd36 fpr 1754 cc rig
Sun Nov 27, 2011 8:07 am
yep sounds like the swicth
driving a gd in ur lake
and i aprove this message
Sun Nov 27, 2011 9:00 am
sweet, i really hope that is what it is, simple fix and i dont have to be without it for a while. I am on a 20 something day turnaround and dont have time to bring it anywheres, and when i get off the TA it will be the beginning of the second split. SOOOOOOOO............ hope you guys are right and thanks for all the information and input!
Sun Nov 27, 2011 8:54 pm
call pd kp will take care of ya
Sun Nov 27, 2011 9:31 pm
X2 ^^^^
Sun Nov 27, 2011 9:41 pm
You can get that Allen head plug at your local hardware store for a buck or two. The power trim sounds like you either have some air in the system, you are low on fluid, or a loose/corroded connection in the power trim switch. All of which are very easy to fix and you won't need PD for any of it.
Wed Nov 30, 2011 9:54 pm
Well, did u make the call r did u just throw your crappy boat away?
18'x54"CC Hanko/ 36PD
Thu Dec 01, 2011 7:52 am
Users browsing this forum: No registered users and 105 guests
