It is currently Wed May 14, 2025 9:29 pm
Reply to topic  [ 9 posts ]
 How much gear lube PD
Post How much gear lube PD
How much gear lube does the old style PD lower unit hold. Mine was fully drained over the course of 2 hours and when I refilled it I could only get it to hold 16 oz. which is half of what I was figuring. I even put the plug back in and hand turned the prop 2 revolutuions to make sure there were no air pockets. When I removed the plug gear lube started pouring out so it must be full. What do ya'll think
Thu Dec 22, 2011 10:19 am
Post Re: How much gear lube PD
You are supposed to fill it from bottom plug. That's close thou
Thu Dec 22, 2011 10:23 am
I did fill it from the bottom plug, and as I stated it started running out the top when I hit 16 oz. in. I put the top plug in, removed tip of bottle from lower hole and put that plug in, hand turned prop 2 revs and checked level at top plug which was still showing full so evidently no air pockets causing a misread level.
I'm just curious why this time it only took 16 oz. I was thinking more along the lines of 32 oz. (1 qt.)
Thu Dec 22, 2011 10:53 am
if you think about it isn't much room in there for it . the Lu housing isn't very big and the shaft takes up most of the room
Thu Dec 22, 2011 10:58 am
Might be a dumb question, But why do they recomend filling from the bottom to the top, instead of leaving the bottom plugged and filling until it reaches the top fill hole?
Thu Dec 22, 2011 11:07 am
they claim that air can be trapped in the needle bearings when filling it from the top. i am not sure about it because i believe it will work its way out in about .03 seconds. thats them not me
Thu Dec 22, 2011 11:10 am
fill from top until it runs out and then recheck it after you run it. Done
Crisis defines character
Thu Dec 22, 2011 11:22 am
Takes less than a qt. I always fill from top. I actualy over fill a bit and then plug it. You could turn the prop by hand if you think you need to work the lube down. Every time I have changed the lube it was still slightly over filled.
18x48 Charles Leonard / 36PD
Thu Dec 22, 2011 6:37 pm
Thanks guys!
Thu Dec 22, 2011 9:26 pm
Users browsing this forum: No registered users and 116 guests
