Mud Buddy vs Go Devil prop http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=25831 |
Author: | duckdoctor [ Mon Jan 16, 2012 7:17 pm ] |
Post subject: | Mud Buddy vs Go Devil prop |
I recently purchased a mudbuddy big blade prop to replace my existing 3 blade go devil prop. There is no comparison, the go devil is 3 times the prop if you look at the numbers. On the go devil prop, I went around 100 miles of sandy river bottom before I had to change it. On the big blade, it was around 20 miles. Not only that, the prop wears completely different as you can see (both have lost right at an inch). The mud buddy just couldn't stand up to it. Any one else have this kind of problem? |
Author: | fowl livin [ Sun Jan 22, 2012 7:14 pm ] |
Post subject: | Re: Mud Buddy vs Go Devil prop |
I noticed the same thing with my prop. I had the big blade on and then put a three blade on and it made the biggest difference. |
Author: | Gigafowl [ Sun Jan 22, 2012 7:32 pm ] |
The GD 3 blade is much thicker and likely a harder material or a better heat treatment.... I have had bad luck with prop rebuilds too because the metal is so much softer it wears quite rapidly.... |
Author: | CAJUN OUTLAW [ Sun Jan 22, 2012 8:57 pm ] |
I looked at ya numbers and I come out with 5x the prop. ![]() ![]() |
Author: | Barroll [ Sun Jan 22, 2012 9:17 pm ] |
Was there a speed difference? Tiller torque? Hole shot? |
Author: | fowl livin [ Sun Jan 22, 2012 10:52 pm ] |
As for speeds I didnt have a gps but it felt close and as far as my hole shot it was night and day difference for the better but there is a significant increase in tiller torque. |
Author: | duckdoctor [ Tue Jan 24, 2012 9:12 pm ] |
As far as speed goes, the brand new Go Devil prop would push 26-27. The Mud Buddy prop was 22-23. The hole shot is night and day - Go Devil gets me up and going much faster. And, when you hit it, you better hang on. |
Author: | centxhunter [ Wed Jan 25, 2012 9:21 am ] |
Out of curiosity, which motor was this on? Most importantly, what were the pitches? That will make a difference, though not sure if the pitch should be different on the 3 vs. the 2. I also wonder about the gearing in the different motors, and how that relates to the prop blades/pitch. |
Author: | Gigafowl [ Wed Jan 25, 2012 11:18 am ] |
The GD 3 blade only comes one way - 11x12 pitch ( although IMO it is 11.5 pitch ) Believe the MB Big Blade is a 12 x 10 pitch - not sure what his was in the pics above it might have been a different version - maybe 12 x 12 Normally the guys with heavy rigs like the MB due to the lower pitch but say it does not last as long in the chit as the GD 3 blade does.... MB offers various pulleys and gearing from 1.2 to 1.5 to 1 GDSD comes stock with 1.4 to 1 gearing |
Author: | FSUDrew99 [ Tue Aug 12, 2014 7:32 am ] |
The MD big blade prop is stainless steel correct? |
Author: | LA Prop [ Fri Aug 15, 2014 12:40 pm ] |
Mb is a 10 pitch which will work a lot better on large heavy boats vs small light boats if u turning to many rpms u need to have it worked so it'll grab the same AS the 3 blade |
