| HELP!!! Home build http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=27286 |
| Author: | backwater7 [ Thu Mar 01, 2012 6:38 pm ] |
| Post subject: | HELP!!! Home build |
Could someone please help, i buit my own SD Looks great work for 5 min then belt started to slip! could one of yall please tell me what type of pulleys and belt or clutch these motors take. I have a 18h kolar rpms are about 3600, would love some help ive put in alot of time and effort into this build any help would be appraciated also were i could get this stuff would be great! |
| Author: | duckduckboom [ Thu Mar 01, 2012 6:49 pm ] |
| Post subject: | Re: HELP!!! Home build |
what kind of belt |
| Author: | backwater7 [ Thu Mar 01, 2012 7:05 pm ] |
i put a 50 inch v belt on a 3.5 top pulley and a 4inch on the bottom i have no clue what type of set up these SD motors use, ive built this motor just buy looking at pics of MD and Gator tail. |
| Author: | CCC [ Thu Mar 01, 2012 7:58 pm ] |
Timing belt |
| Author: | BlueShamu [ Thu Mar 01, 2012 8:01 pm ] |
Let's see some pix of this home build! |
| Author: | sftull [ Thu Mar 01, 2012 8:02 pm ] |
Chain and sprockets...alot cheaper than a timing belt setup and it won't slip!! |
| Author: | CCC [ Thu Mar 01, 2012 8:11 pm ] |
| Author: | barrelburner [ Thu Mar 01, 2012 8:52 pm ] |
v-belts are not the best, slip too much for this application. Like the other guys said chain and sprockets or timing pulleys with 3/4 to 1 inch wide belts. I used martin H pitch timing pulleys for my build, the H is for heavy duty ba beeeeeeh. Think I had about 150 bucks tied up in them+ the tapered bushings to go in them for the right size bore. Don't give up these home builds will whip your butt if you let them. |
| Author: | backwater7 [ Thu Mar 01, 2012 9:19 pm ] |
man thanks alot your right im about to pull out my hair! i got this thing done stuck it in the water it worked fine right off the bat then the more gas i gave it the slower it ran! i thought i was done with this thing! |
| Author: | backwater7 [ Thu Mar 01, 2012 9:55 pm ] |
Here are a few pics of the motor |
| Author: | backwater7 [ Thu Mar 01, 2012 10:30 pm ] |
idont have the finished pics yet but there coming |
| Author: | SCmudder7071 [ Fri Mar 02, 2012 12:01 am ] |
That brace is gnarly looking! I like the vintage coke machine also |
| Author: | sftull [ Fri Mar 02, 2012 7:21 am ] |
I'm using a outboard transom mount on my build as well and have been struggling trying to fab up a trim system. The ob mount has holes for statics trim positions but I wanted to be able to adjust it on the fly. Any ideas as far as the trim and very nice build. |
| Author: | backwater7 [ Fri Mar 02, 2012 5:17 pm ] |
coke machine was put on the back burner for now i need to finish it soon! as far as the trim goes, man mine only works when i lift it out of the water. that was the only thing i didnt think threw. mine would have worked better if i had lowerd it 3''. i tried to copy copper head MM theres seems to work good. if you had anymore questions be happy to answer them! |
| Author: | BlueShamu [ Fri Mar 02, 2012 8:56 pm ] |
Man that is awesome that you were able to fab up that motor! Best of luck with it. Let us know how it turns out. |
| Author: | flyerfly [ Thu Mar 08, 2012 1:31 pm ] |
Man I hope no one accidentally trips and falls on that brace...could really hurt !! |
| Author: | stualaska [ Thu Mar 08, 2012 3:51 pm ] |
| Author: | Quackkillz [ Fri Mar 09, 2012 5:48 am ] |
I wish I had some helpful tips but I've never tried to build my own but it looks cooler then a polar bear's toe nail and I'm sure you'll get the bugs worked out soon....keep us posted, good luck! |
