It is currently Wed Dec 24, 2025 2:37 am
[ 3 posts ] |
HUNT4DEER
Joined: Sun Jan 03, 2010 10:39 am Posts: 833 Location: DODGIN ROCKS ON THE RIVER OR CARS ON THE INTERSTATE
 a little water ?
have a mini lite. pulled the grease plug and pumped a little grease in. well i could tell there was some water contamination. pumped a few shots of grease in and got to good grease. ran it for a little while (oow) and everything seems fine. no noise or excessive heat at the bearings. i did try to pull the lower bearing cap but it wouldnt budge, so i put the prop back on. should i run it or tear it down now? if i do run it what other than the bearings (if there bad now runing them wont hurt them any worse) what else would it hurt?
| Thu Mar 15, 2012 8:06 pm |
HUNT4DEER
 Re: a little water ?
86 views and no comments?
| Sat Mar 17, 2012 1:31 am |
med
Joined: Wed Jan 14, 2009 8:25 am Posts: 6432 Location: the dark side of the moon
A bad bearing will eat the drive shaft. You might post this at the mb forum. You might get more info there.
_________________ 1850 & 36pd
| Sat Mar 17, 2012 1:56 am |
[ 3 posts ] |
