It is currently Tue Dec 23, 2025 1:14 pm
Reply to topic  [ 11 posts ]
 gtr belt change
Post gtr belt change
Can some one give me the steps to change a belt on a gator-tail gtr 35. I know you have to remove the lower shaft. Can you please post the steps.
Sun Aug 15, 2010 4:57 pm
Post Re: gtr belt change
I heard there was a LIFETIME warrenty on the Belts....
Sun Aug 15, 2010 5:47 pm
There is a life time J, but if you are doin it yourself you remove the lower unit bolts and pull lower unit off, then you remove clutch housing (if you have GTR you'll probably have to remove the reverse caliper) then you pull belt out the top of the unit. Pretty easy and straight forward.
Sun Aug 15, 2010 8:30 pm
I did all of this but I can not get the belt back on the lower unit while I have the top of the belt on the clutch. Is there a trick or do you have to remove the clutch off the engine and then put the belt on the lower belt gear? I have the old one off but can not get this thing back together.
Mon Aug 16, 2010 5:54 am
MMT Moderator
Not sure if this is the fast way but I would remove the lower unit output shaft lift it clean off the belt then remove the belt from the top. Replace the belt and put the lower unit back in.
You should be able to slide the lower unit back in by lifting then sliding it in. Hoyt said one person should do this as it has to go in just right. He removed the lower unit at SETX run for someone.
GTB 1860 w/ 2019 GTR40XD-HO
Mon Aug 16, 2010 6:30 am
It has to be angled just right to get that bottom of the belt on. You may have to angle the prop towards the ground to get the belt on the lower gear and once it slides on you can push it in and put a couple of bolts in the flange part and spin the prop to make sure the belt works its way all the way on the lower gear. then with a flashlight shine down from the top and make sure belt is all the way on then you can proceed to put the rest of the bolts in the lower unit, when fully installed recheck belt and make sure its tight and all the way on the lower gear.
Mon Aug 16, 2010 7:00 am
Get you a piece of string and put it around the belt on the bottom. Pull down on the string to stretch the belt downward while putting the lower unit in the belt. You initially have to tilt the outdrive point the lower gear up to get it started on the belt. Then with the sting you should be able to assist and get the belt positioned correctly. Then pull the string out. Its a one person job. Once you get everything lined up just right with the help of the string it will go together easily.
Mon Aug 16, 2010 2:56 pm
Mon Aug 16, 2010 3:17 pm
I used a piece of wire and installed in 10 min.
THANKS FOR ALL THE HELP GUYS.
Mon Aug 16, 2010 7:47 pm
talked to a gator tail mechanic and he said it takes about an hour. you loosen all the motor mount bolts and remove the ones on the tiller side and tilt the motor back and prop it up after removing the housings and the belt slides right on and right off.
Fri Mar 16, 2012 6:02 pm
two year old thread bud
Fri Mar 16, 2012 6:06 pm
