| a little water ? http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=27693 |
| Author: | HUNT4DEER [ Thu Mar 15, 2012 8:06 pm ] |
| Post subject: | a little water ? |
have a mini lite. pulled the grease plug and pumped a little grease in. well i could tell there was some water contamination. pumped a few shots of grease in and got to good grease. ran it for a little while (oow) and everything seems fine. no noise or excessive heat at the bearings. i did try to pull the lower bearing cap but it wouldnt budge, so i put the prop back on. should i run it or tear it down now? if i do run it what other than the bearings (if there bad now runing them wont hurt them any worse) what else would it hurt? |
| Author: | HUNT4DEER [ Sat Mar 17, 2012 1:31 am ] |
| Post subject: | Re: a little water ? |
86 views and no comments? |
| Author: | med [ Sat Mar 17, 2012 1:56 am ] |
A bad bearing will eat the drive shaft. You might post this at the mb forum. You might get more info there. |
