It is currently Wed Dec 17, 2025 12:29 am
Reply to topic  [ 35 posts ]
 Belt change
Post Belt change
What's the easiest way to put a belt on a gtr?
1754 GTB / 35 GTR
Wed May 09, 2012 2:25 pm
Post Re: Belt change
oh boy,,,better brace yourself on this one.
HOTSAUCE170 wrote:
Wed May 09, 2012 3:06 pm
Post Belt change
Pull off the lower unit.
Wed May 09, 2012 3:42 pm
Thu May 10, 2012 6:18 am
Ok is there a seal on the lower unit?
1754 GTB / 35 GTR
Thu May 10, 2012 7:01 am
A rubber o ring. clean it and if you want you can lube it with a Light oil or grease... Dont have to but its extra insurance.
Thu May 10, 2012 7:21 am
Post Belt change
With a box end wrench it's s 10 minute job with a ratchet wrench 5 minute. Power toll 2 minute lol
17x48 extreme stage 2 GTR
Thu May 10, 2012 7:34 am
I think you should make a video Terry.
I call BS on 2 minutes by the way!
You can prove me wrong though, and it will only take 2 minutes. I'd say it's worth it. lol
Thu May 10, 2012 7:49 am
Post Belt change
Thu May 10, 2012 8:07 am
Post Belt change
I seen Hoyt walk up to peacocks motor at SETX a few years ago and pull it off in less than a minute!! With a ratchet wrench!
Thu May 10, 2012 8:10 am
Post Belt change
Why'd he pull it off?
Thu May 10, 2012 8:19 am
was his old motr IIRC. Really a belt swap is pull the LU and brake caliper.. Plus if you never took off the LU Salt corrosion fills the threads and holes... Had to beat mine off when I changed my bearings.
Thu May 10, 2012 8:39 am
Post Belt change
Thu May 10, 2012 9:39 am
I mean it don't take long. But a question I have some grease in the belt housing. This ok?
1754 GTB / 35 GTR
Thu May 10, 2012 11:42 am
Post Belt change
Old grease? New grease?
Seal could need changing.
Thu May 10, 2012 12:12 pm
Little of both. Just pump some threw without takin drain screw out came out the back right before the gear
1754 GTB / 35 GTR
Thu May 10, 2012 12:35 pm
Need a new seal and wear sleeves!
BTW take the screw out Dude. If you pump grease without taking it out you will push greas out past your seals..... COmmon sense will tell you that. the seal can only hold SO much pressure then it will deform and grease will escape.
Thu May 10, 2012 12:36 pm
Post Belt change
That how it supposed to be !! They put the seals backwards so as you did you pumped grease with out taking the screw out you won't blow the seal!! Take the screw out !!
Thu May 10, 2012 12:37 pm
He is talkin bout the seal by the pulley. that one isnt like the ones by the prop
Thu May 10, 2012 12:39 pm
Grease was already comin out since it was already in the belt housing. Was trying to figure out wher it was comin out. Well it popped out the back. Seems to be comin out a tiny hole
Btw I always take it out. First time I didn't
1754 GTB / 35 GTR
Thu May 10, 2012 12:54 pm
Ship me your LU and I'll change it for 100 cash!!!!
Thu May 10, 2012 1:06 pm
Haha don't have that kinda cash. But I'm sure I can do it. But now I have to pull off the pulley?
1754 GTB / 35 GTR
Thu May 10, 2012 1:13 pm
Post Belt change
Thu May 10, 2012 1:43 pm
Yeah you have to pull the taper lock bushing off the shaft. Take out the bolt and washer in the middle, Take out the 2 allen screws that hold the pulle to the taper lock bushing. Then take one of them screws and put it in the third Empty slot and tighten it, It will push the pulley off then you can tap off the bushing. Replace seal and wear sleeve. Get some good snap ring pliers cause that snap ring that holds the seal from popping out is a BEAST.
Thu May 10, 2012 1:50 pm
Thanks 08 210
1754 GTB / 35 GTR
Thu May 10, 2012 2:26 pm
Damn right on that snap ring
1754 GTB / 35 GTR
Thu May 10, 2012 3:42 pm
Thu May 10, 2012 3:44 pm
Thu May 10, 2012 4:07 pm
Ok got everything back together slinging grease out near the prop.i guess I need a new seal there how do u get to this one?
1754 GTB / 35 GTR
Wed May 16, 2012 12:37 pm
viewtopic.php?f=3&t=20548&start=40
read my post
Wed May 16, 2012 1:25 pm
ugh damn this doesnt sound fun
1754 GTB / 35 GTR
Wed May 16, 2012 2:24 pm
Not bad. Maks sure you just dont have too much grease ... Run it and see if it stops. the seals are installed so if you pump too much it will let excess grease out.
Wed May 16, 2012 2:41 pm
No I found the old seal is dry rioted. When u were talkin about the threads are u saying that there backwards like its not righty loosey lefty tighty?
1754 GTB / 35 GTR
Wed May 16, 2012 3:07 pm
Post Belt change
Si seƱor
Wed May 16, 2012 3:45 pm
Left hand threads... Left to tighten, right to loosen.
