Need to make a drive shaft for a 9hp diesel long tail
http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=27873
Author:  takoateli [ Thu Mar 22, 2012 9:09 pm ]
Post subject:  Need to make a drive shaft for a 9hp diesel long tail
I have a drive shaft which I had made but it's not straight and I need to make another. It's for a 9hp diesel engine with a lot of torque for a 9hp. What should I make the drive shaft out of? I needs to be 1" or less in diameter.
Thanks!
Greg
Author:  Woodiebuster [ Thu Mar 22, 2012 9:28 pm ]
Post subject:  Re: Need to make a drive shaft for a 9hp diesel long tail
Where are you getting your prop from?
The industry standard is a 3/4" 10 tpi threaded hub on a 3/4" shaft with a keyway in the u-joint end, that will hold up fine.
Author:  takoateli [ Thu Mar 22, 2012 9:32 pm ]
I have a Hopkins Propeller MB1 but I really need the MB11 I believe.
My motor runs a straight shaft, no u-joint.
And my prop goes on a smooth shaft with a shear pin.
But what is the shaft itself made of? That's what I need to know. I need to have one made here in Venezuela. You can see the motor at http://gregihnen.me
Author:  Quackkillz [ Thu Mar 22, 2012 11:14 pm ]
Go devil uses carbon steel
Author:  Mag10 [ Fri Mar 23, 2012 6:40 am ]
I typically use 3/4" 17-4 H1150 or 4140 Heat treated turned ground and polished. On a 9 hp you could probably get away with using cold rolled 1018.
Author:  takoateli [ Fri Mar 23, 2012 7:26 am ]
Author:  slimboo1 [ Fri May 11, 2012 8:50 am ]
i fished there in the past .... what a wonderful place... i would use 3/4" hot or cold roll steel... look at support races on metal buildings ... if memory service me they us that size too... good luck
Author:  takoateli [ Wed May 16, 2012 7:36 am ]
Author:  indawoods [ Fri May 18, 2012 4:10 am ]
every drive shaft on every mud motor made here in the states is a solid shaft, 3/4" for your application. 4140 stainless is common, cold roll steel will work and does for home builds on the cheap. with as many stumps/logs as you encounter, I would go with the solid shaft, not a tube. get the stainless if you can.
