It is currently Fri Dec 26, 2025 2:57 am
Reply to topic  [ 25 posts ]
 GTR 35 pulls left
Post GTR 35 pulls left
My GTR 35 pulls left. Its not so bad that you cannot stand it, but after a long run your arm gets tired. The guys at GT taold me I could bend the plate on the lower unit to get rid of this.
My question is has anybody had to do this yet?
I have adjusted my load every which way possible. It gets better with every thing on right side of boat but I don't like it that way. I want to load the boat the way I want it loaded any ideas will help.
Real men use a Stick and String
Mon May 07, 2012 2:24 pm
MMT Moderator
Post Re: GTR 35 pulls left
These boats like to be loaded even. Yes you can bend the skeg we all do it. But finding the balance in the boat is key...
GTB 1860 w/ 2019 GTR40XD-HO
Mon May 07, 2012 2:38 pm
I spent probably 36 hours straight this weekend on the water. My brother and i loaded boat even; just the way it should be. We loaded heavy on right; we loaded heavy on left. heavy on right took most of the pull out of the motor, but boat set wrong in water. I have been around boats all my life I understand how to load one.
What is the best way to bend the skeg and how much do you need to bend it? My GTR has a small cut out piece that is already bent slightly to left if you are standing behind motor. Is that the piece you want to bend back?
Mon May 07, 2012 2:52 pm
Yes..bend that part of the skeg in the opposite direction of which it pushes.
Mon May 07, 2012 2:58 pm
what is the easiest way to bend it? Take big wrench and bend?
Mon May 07, 2012 3:44 pm
I screwed on one of the torque tabs on the Port side of my skeg. It cured Most of my pulling. WHen I have a load I can balance it all out and actually the boat does better with weight in it.
Mon May 07, 2012 3:48 pm
MMT Moderator
I can feel my dog walk around the boat on the way to the blind each morning. I added a larger torque tab & bent my skeg with a large wrench.
Mon May 07, 2012 3:57 pm
Again guy I am a freaken newbee. What is a torque tab? And where do I get one? i like that idea better than bending my skeg.
Mon May 07, 2012 4:12 pm
Mon May 07, 2012 4:17 pm
IF you put alot of weight on one side and it took alot of tiller torque out, have you made sure that your motor is centered on your transom, just a question but i have seen it before. I can understand moving a little weight here and there but if you put alot of weight on one side and it cured alot of it that very well may be your problem
Mon May 07, 2012 7:53 pm
I've got the same problem. Usually I put everyone or everything in the middle, with just a little extra on the right. Cant put anyone or anything on the left or it pulls too hard for comfort. I've been meaning to bend the torque tab just havent gotten around to it.
Mon May 07, 2012 8:10 pm
mines doing it to, my hands were swollen from holding that handle for a long run
35gtr on a 1854 Deep South Custom
1436 flat pushed by a 16 GDLT
Mon May 07, 2012 8:19 pm
If yall arms are hurting maybe yall should go Stroke it with yall lefts to build up some left arm stamina!
Tue May 08, 2012 5:46 am
If your motor isn't bolted on or you want to move it you can push your motor over 1" and it will help!! Were do you drive it from on the side of the tiller or in front of it!! Believe me you can get it to were it won't pull at all just have to make adjustments till it's right !! What kind of boat is it on also
17x48 extreme stage 2 GTR
Tue May 08, 2012 7:15 am
Tue May 08, 2012 7:21 am
I've heard of people doing this is why i said something about it, fixed their problem and ain't heard a word since
Tue May 08, 2012 5:52 pm
My motor is dead center. I took alot of time to make sure. I plan to bend skeg to right just a little and see what happens.
As for stoking it with the left hand; I have found if you will first sit on your left hand till it gets numb from lack of blood then stroke it, it is like some one else is doing it for you.............
Tue May 08, 2012 7:03 pm
The sd's I've had have all been mounted 1" off center
1850 & 36pd
Tue May 08, 2012 7:07 pm
What side of center
Gator tail boys told me to mount mine in the center
Tue May 08, 2012 7:14 pm
Tue May 08, 2012 7:30 pm
Post Re: Re: GTR 35 pulls left
1850 & 36pd
Tue May 08, 2012 7:55 pm
My left or your left?
Tue May 08, 2012 8:00 pm
Should be the same unless you walk backwards
1850 & 36pd
Tue May 08, 2012 8:03 pm
Dead center. Bend skeg. If that don't fix it, move motor 1" to port side.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Tue May 08, 2012 8:10 pm
K thaks I will bend skeg and see
By the way I do walk backwards and with a limp.......................
Wed May 09, 2012 1:18 pm
