It is currently Mon May 12, 2025 9:36 pm
[ 3 posts ] |
CrazyRaginCajun
 Need a prop
I have a 100lb pedal/paddle boat that well isnt much fun anymore lol After a ton of reading on here i decided to make a short tail. I have a honda copy 6.5hp, clutch (10 tooth) and a 14in jackshaft kit (3/4in with 3/32 keyway) with a 10 and 14 tooth sprockets. im not going to run shallow water, just rivers/small lakes/ponds and what not i cant pedal against or for as long as i need to.
Any idea what prop will fit this shaft without too much trouble?
Mon May 28, 2012 7:45 pm |
BoatDR
 Re: Need a prop
If you arent going to be in any shallow water, save yourself alot of headaches and just get a trolling motor.
But if you are determied to make that motor work, I'm sure Copperhead or Dixie mudmotors would sell you a prop.
Tue May 29, 2012 9:34 am |
CrazyRaginCajun
 Re: Need a prop
the fish im going after need 2ft+ of water. i thought about the trolling motor route, as i have one but its old and pretty much doesnt work, and for the cost and aggravation of needing the battery, i really want to stick with that i have.
if i could have found a lower/middle section from an outboard i could use a 6.5 vertical shaft i have.
Tue May 29, 2012 9:50 am |
[ 3 posts ] |
Users browsing this forum: No registered users and 123 guests |
