It is currently Fri Mar 20, 2026 8:57 am
Reply to topic  [ 16 posts ]
 Replacing the driveshaft??
Post Replacing the driveshaft??
Can anyone tell me if this is a pain in the ass? I have an '05 threaded prop that simply won't come off. I've tried everything heat, torque, cutting, you name it. Now I'm breaking tilt/trim units......so I'm down to replacing the drive shaft. I'm sure I can't afford a new outdrive.
Any pointers would be great. I already have a replacement prop and belt, so I'm hoping a driveshaft swap is feasable. Thanks in advance.
-Greg
New Era Championship Calls
DO YOUR DAMAGE
Sun Feb 17, 2013 6:54 pm
Post Re: Replacing the driveshaft??
PM Gigafowl...he can probably help you out.
Sun Feb 17, 2013 6:56 pm
I'm assuming it a gd just undo bolt on u joint and tap the shaft out. A new shaft is $65
Sun Feb 17, 2013 7:00 pm
Sounds like mud buddy. [ tilt/trim]
Sun Feb 17, 2013 7:01 pm
Yah, it's a M/B. I saw a post on here asking why so many M/B guys ask questions on the forums? It's because you can never reach Micah or Justin @ M/B. No reply to e-mails or voice mails.
I hope the D/S is an easy swap. I need to also replace the tilt/trim piston and I hope to get this baby in the water. I just got heads, carb, intake/exhaust done and want to see how it pushes.
DO YOUR DAMAGE
Mon Feb 18, 2013 11:55 am
Finally got ahold of M/B. It turns out that they don't even supply the driveshaft any more, 36". He said I would have to buy a complete outdrive, @ $650.
I removed my O/D and I'm gonna pull the driveshaft myselft and see what I can do. I think I'll be looking into a Pro-drive in the future.
DO YOUR DAMAGE
Tue Feb 19, 2013 1:26 pm
Tue Feb 19, 2013 1:30 pm
^ Don't mind him. He has a GoDevil. What do you mostly run? Marsh, timber, lakes, swamp?
"There's nothing a duck hunter hates more than another duck hunter"
Custom 17x48 with a new Gen III Prodrive.
Tue Feb 19, 2013 1:43 pm
1846 GTB and 35 GTR
New GT Rig
Old Surface Drive Build
Tue Feb 19, 2013 2:47 pm
Tue Feb 19, 2013 3:02 pm
B. MacDonald
Tue Feb 19, 2013 4:02 pm
I'm a sheet metal guy and work nightly with machinists. It just pisses me off that I can't get parts for a motor that's only 7 years old.
DO YOUR DAMAGE
Tue Feb 19, 2013 6:20 pm
3/4" cold rolled round stock cut to length,machine a couple inches of keyway on one side, 3/4x10 threads on the other
1436 Lowe
Wed Feb 20, 2013 8:41 am
^ive done this for a longtail and it only cost $60 total (materials and labor) should be closer to $40 for a shorter shaft.
Wed Feb 20, 2013 1:49 pm
DO YOUR DAMAGE
Thu Feb 21, 2013 10:08 am
DO YOUR DAMAGE
Thu Feb 21, 2013 10:15 am
