| rpm and prop ? http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=30545 |
| Author: | barrelburner [ Fri Jul 06, 2012 4:51 am ] |
| Post subject: | rpm and prop ? |
Just a general question for the experts. Quick summary goes like this. I am now running a 9x8 hill prop on my 6.5hp surface drive and am very pleased with its performance. I am able to turn, with the gov tweaked that is, around 3900 rpms in the water. Everybody usually talks about pitch, but do you guys think I would be able to turn a 10x8 surface prop and will I gain anything? Any thoughts? I think I am getting close to the limits of this little motor and she does not have much more to give. |
| Author: | mud slinger 69 [ Fri Jul 06, 2012 7:00 am ] |
| Post subject: | Re: rpm and prop ? |
Thats alot of prop for a 6.5.Dont know if i would change it if your running good.What speeds are ya getting and what boat is it on? |
| Author: | barrelburner [ Fri Jul 06, 2012 9:20 am ] |
14x36 riveted jon, speeds right now are an honest 14-15mph, but she has alot of low end grunt and torque. |
| Author: | mud slinger 69 [ Fri Jul 06, 2012 1:55 pm ] |
I dont know as much as some of these guys.But i think thats pretty good for a 6.5hp motor if ya could find one to try and not have to buy it then id try it see what happens.Ya dont want to work that motor to hard. |
| Author: | Broke Okie [ Sat Jul 21, 2012 1:08 pm ] |
What brand of engine are you running? What gear ratio? What all have you done as far as mods? I'm building a 6.5 as well and trying to decide what prop to buy. 9x8 according to prop manufacturers is suitable for 23 to 27 hp but if you are getting good performance I may think about it. just hate to spend 160 + on a prop I hate. |
| Author: | barrelburner [ Sat Jul 21, 2012 3:56 pm ] |
Engine is a 6.5 harbor freight greyhound honda clone with header, high flow air filter, rejetted carb and gov a little tweaked. Gear ratio 1:63.1. I have a nice new 9x6 lite backwater inc prop if your interested. I will take 120.00 shipped. |
| Author: | Broke Okie [ Sat Jul 21, 2012 5:07 pm ] |
Thanks, same engine I have. I will definately think about that prop and try to decide by monday/tuesday. |
| Author: | Mag10 [ Tue Jul 24, 2012 4:11 pm ] |
I would spend another $50 for a top (driver) pulley before spending $200 for a prop. Try closer to a 1.3:1 reduction. Getting that prop spinning a bit faster will accomplish about the same thing as adding pitch to a prop. Mag10 |
| Author: | Broke Okie [ Tue Jul 24, 2012 5:45 pm ] |
That might work out if I already had a prop but I don't so a higher gear ratio won't do me much good. |
| Author: | Mag10 [ Wed Jul 25, 2012 8:15 pm ] |
Sorry, that was directed at barrelburner |
| Author: | Broke Okie [ Wed Jul 25, 2012 8:19 pm ] |
Oops, my bad |
| Author: | Broke Okie [ Sat Aug 18, 2012 10:58 am ] |
Barrelburnner, do you still have that 9 x 6 prop and if so is it stainless? I cant find any hill props that are "lite" so just wondering the difference. |
| Author: | barrelburner [ Sun Aug 19, 2012 5:10 am ] |
Broke, prop is stainless back water inc. I told arlon at backwater my set up and this is what he specified for my hp and gearing. Prop is still available and is a longtail prop. Worked very well and I just dont run alot of mud but shallow water so I went with 9x8 for a little more speed. Guess he specified it as a lite 9x6 because he machined it for my set up. |
| Author: | Broke Okie [ Sun Aug 19, 2012 9:18 am ] |
Ok, that makes sense. I don't run much mud either, mostly open water, some is very shallow but I don't have that mucky mud, ours is different. Thinking about a 9 x 8 also Sent from my Motorola Electrify using Tapatalk 2 |
