rob_E
Joined: Wed Jan 25, 2012 12:03 pm Posts: 1763 Location: Prairieville, LA
 Help removing prop shaft
How do you remove the prop shaft on a gator tail surface drive
_________________ 18X54 CC & 35 GTR w/ Hoyts Stage 1
Sun Jul 29, 2012 11:58 am |
Team Camo
Joined: Thu Oct 01, 2009 4:49 pm Posts: 8536 Location: Bridge City, TX
 Re: Help removing prop shaft
Just the outdrive or the actual shaft from the outdrive?
_________________ 1846 GTB & 35 GTR Team Gator-Tail
Killer Kallz & ANGLE PORT dealer (409) 720-8949
Sun Jul 29, 2012 12:08 pm |
rob_E
The actual shaft from the out drive
Sun Jul 29, 2012 12:11 pm |
rob_E
Please describe just the outdrive
Sun Jul 29, 2012 12:41 pm |
Team Camo
Remove gear & snap ring, then front & real seals & bearings. Should be able to slide shaft out then.
Sun Jul 29, 2012 12:46 pm |
Bayoublackhunter
Joined: Sat Oct 02, 2010 4:55 pm Posts: 1192 Location: BAYOU BLACK
_________________ 35gtr on a 1854 Deep South Custom 1436 flat pushed by a 16 GDLT
Sun Jul 29, 2012 12:54 pm |
Team Camo
Haven't messed with any older than 2010, didn't know there was a difference tho.
Sun Jul 29, 2012 12:56 pm |
rob_E
on the rear there is somekind of spacer on the octagon or whatever shaped part that i cant get off and i got the front seal out but cant budge the bearing shaft is bent any one got some pointers
Sun Jul 29, 2012 4:40 pm |
